Question about Home
The unit will not heat any water, press hot but goes straight to
The unit (triton be-witch) has good water pressure, running from mains pressure, been running for 6 months no issues, pushed hot water button at the top. it didnt light up & went straight on to the cold setting ? tried the warm setting but unit did the same thing. all electrical wires conections are ok ? not sure what to replace ? (help)
    Problem Solver:
  • 5 Answers
Probley heater eliment ? if not megga dear unit buy new one probly cheaper as long as u fit ure self
Posted on May 18, 2009
No hot water in shower. Sometimes runs hot then goes cold or runs cold. I have less than 2 year old Kohler Faucet K-T10448-4-CP. I replaced the pressure balance valve unit. No luck. I changed the hot...
Refer to the manufacturer's recommendations for back-flushing/descaling to flush out mineral deposits and build-up in the heat exchanger. You can check to see if this is a problem by comparing the full cold water flow with full hot water flow at the faucet. If the hot water flow is significantly slower than the cold then the heat exchanger is likely clogged with deposits and will not transfer heat sufficiently. If the flow is good then the heating element(s) maybe defective.
Feb 17, 2015 | Kohler Plumbing
Is it a mains fed shower
The installation must be in accordance with
Water Regulations/Bylaws.
To ensure activation of the heating elements, the
shower must be connected to a mains water
supply with a minimum running pressure of
100kPa (1.0 bar) at a minimum flow rate of eight
litres per minute (nine litres per minute for the
9.5kW rated model).
For all units the maximum static pressure must
be no greater than 1000kPa (10 bar)
If in any doubt, the pressure should be checked.
Sep 16, 2014 | Home
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Triton t90i shower doesn't heat water and lacks power.its about 5yrs old and is used every day
it is temp contrl shower and you could have to take out the cartdrige and change it,, probly clogged and it's not letting the hot water be hot enough, if the pressure is good then the cartridge is bad
Apr 20, 2009 | Water Heaters
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
188 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
