Question about Samsung HLN617W 61" Rear Projection HDTV
I just bought a new lamp for my samsung tv because the tv just want black,I JUST REPLACE THE LAMP a year ago to the date, i went to the store and just install it and it still does not turn on? so i called the store back and they said it could be the balster that turn on the tv? please help! steve
    Scholar:
  • 73 Answers
Steve The part you are inquiring about is called the ballast, It is a small (say 3" x 8" ) circuit board that attatches directly to the bulb via the two pronged leads coming off the bulb. On this set you'll have to take the back off to get to it. Once you do, you'll see it right infront of the optics block, just a couple screws will loosen it. There is a white and black power line and a sleeved reciever line connected to it. Get the model number off your ballast and go to shopjimmy.com rivervalleyelectronics.net or ebay and replace. If I remember correctly. There are several compatible ballasts for this set. Rule of thumb though, is that just because it looks the same doesn't mean it is. Call samsung, they will also sell you the newest, latest and greatest ballast. You can just ask them for a part number too and then shop around. Good luck.
Posted on Jun 06, 2009
  • Axle80
    Axle80 Jun 13, 2009
    Something else you might want to check is the color wheel. These tv's are from circa '03 and the color wheels are an achillies heel for the samsung dlp. You will actually be able to see the color wheel if you look into the spot that the lamp housing occupies, just past where the lamp shines is a 2x2 clear piece of glass, beyond that you will see a part of the color wheel. It should be a symetrical pattern with no missing 'pie' pieces of the wheel. If you see somthing broken, comment back and I'll walk you though the process of checking and replacing the wheel, You can also email me directly at cfoley@hawaii.rr.com.
My Samsung DLP HD 46" TV just went Black &
Defective Color Wheel- Encompass parts Distribution 1-800-638-3328
Mar 06, 2011 | Samsung HLP4674W 46" Rear Projection HDTV
Sony KDS60R2000 Bravia SXRD Full HD - No picture after its switched on. Green light blinking but no picture. Since it was bought (new about 4 years ago) it would occasionly just "switch off" by...
It is time for new lamp in tv as existing has reached on end of its working life.
Replace lamp in tv to fix the problem, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Nov 05, 2010 | Sony KDSR50XBR1 50" Projection HDTV
We have a 2003 60inch? hdtv tv dptv335 the sound works but our picture went out 2 days ago while we were watching. no load noice or bright light..just went black. what do we do? kris
The tv had not been change the projection lamp the last 1 1/2 or 2 years and on used like 4 or 5 hours day.The tv pojection lamp life is over.Replaced a new tv projection lamp.
Sep 15, 2010 | Philips 55PW9363 55" Rear Projection...
My samsung tv went out.
There are a few other problems like the ballast or color wheel. Hear any sounds? Smell anything?
Feb 04, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
My samsung hlr5067r went black no sound or
Tries reinstall ur lamp,check ur power supply for burn parts like capacitors burn,like it puffed up.
Sep 25, 2009 | Televison & Video
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
Lamp Cartridge
Well I bought my about three years ago and that warning was poping on for about a year. The lamp finally went out, I should have got a replacement sooner. But I ran it longer than it should have gone, I think I read the lamp should last about 2 years, I got an extra year out of it. Oh well time for a new one...
May 20, 2008 | Mitsubishi WD62327 TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Hitachi model # 50V720
I have the same model and had the same problem after replacing the lamp. Turns out if the cover plate is not put back on properly, tv will not power on and lamp ligth comes on. To solve the problem all I had to do is tighten the cover plate screw. Hope this helps.
Nov 17, 2007 | Hitachi 50V720 Television
Lamps
color wheel brakes then causes this same affects check your wheel
Nov 05, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
