Question about RCA R52WM24 52" HDTV Projection Television
My tv worked fine this morning then it looked con caved and the auto convergence button is no longer there
  • RCA Master
  • 8,617 Answers
You need to replace the following three components. FL231, DL231 and CL230 you can get the parts with instructions at the following link. They are listed under the RCA parts category.
http://servicemanuals.vstore.ca/
Posted on May 11, 2009
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
Colors look like 3-D
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 05, 2010 | Hitachi 46F500 46" Rear Projection...
The green projection tube is mis aligned. it was
maybe convergence problem. Contact tech support with this #4 display
Jun 03, 2010 | Hitachi 57SWX20B 57" Rear Projection...
The covergence
I have a kp-61v90. I love this tv. Recently the flash focus isnt working,,,,, the colors are not lining up to give me a solid cross in the middle so it makes everything look as if i were wearing 3-d galsses. Yes i can solder, but what am i soldering. Help me please....my man cave is out of commission.
Mar 06, 2009 | Sony KP-61V90 61" Rear Projection...
RCA TV question....
OK you have 2 problems First Go to Capacitors cp150 2200uf 16 v look to see if it is puffed up on top if so replace it and 2 others cp114,cp120 220uf 35 v . The fuse you are looking for is on Right side of (FBT) flyback Transfomer there is 3 of them the one in the middle is the convergence Fuse FL231.Go to http://servicemanuals.vstore.ca they will have what you need ! If you need anymore help let me know. Happy New.
Dec 30, 2008 | RCA D52W23 52" HDTV CRT TV
Looks like watching 3D movie(colors) and rounded
This is a convergence problem and is either bad connections on the convergence ICs or defective ICs. If you feel that you can solder, you should be able to repair this yourself. First try resoldering the pins on the convergence ICs. If that fails, replace the ICs. These ICs are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
May 13, 2008 | Toshiba 57HDX82 57" Rear Projection HDTV
TOSHIBA 65H82
you need to replace your 2-convergence ic's #STK392-110 you need to replace both ,,they are attached to 2 big heat sinks and identified as q-751 & q-752 you can get the ic's you need plus free tec support and installation instructions including pictures at the link I gave you.
Apr 12, 2008 | Toshiba 65H82 65" Rear Projection...
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Loss of convergence after powering off.
you must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Apr 29, 2007 | Samsung PCN5425R 54" Rear Projection...
Convergence issue
You can go back to factory settings by pressing and holding the ACTION and POWER buttons on the TV while it is on. A CHK screen will appear and when it does release the buttons and then power the set off then on again. This had reset all settings back to factory conditions. You will have to reprogram any channels into memory after this.
Mar 29, 2007 | Panasonic PT-51G44 51" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
105 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
