Question about ASUS A8N-E Motherboard
NO MONITOR OUTPUT
NO OUTPUT ON MONITOR BEEPS ARE EMITTED ON START UP BUT CANT TELL IF THERE ARE 3 SHORT BEEPS OR 1 LONG AND 2 SHORT.
HAVE CHANGED THE GRAPHICS CARD BUT STILL NO GO
  • Anonymous Mar 16, 2014
    1 LONG BEEP, 3 SHORT BEEPS
The mother board has died. Im on my 3rd board under warranty!!!!! there is a small fan on this board, underneath is a nvidia graphis chip that fries and when it goes it makes that beeping and shows nothing on the monitor.
1st time lasted 15 months then fried above mentioned chip under fan ,electrical smell.
2nd time lasted 2 months no smell just beeps and nothing on monitor.
3rd time still putting back together.
every time the board was replaced not repaired, check serial number
Posted on Dec 16, 2007
  • 385 Answers
Check your ram. Just take it out, clean it and reseat it to reinforce connectivity.
Thanks,
Lolita
Posted on Oct 12, 2007
What do the beeps codes i am getting mean? 1 short followed by 1 long.
Beep codes don't cause or signify damage, they are just telling you something is wrong. In your case, I would say the RAM is incorrectly seated or in the wrong slots.
2 beeps Memory (RAM) not detected
Remove the RAM and press it HARD until it locks in place. Do a visual check that the indent is against the mounting.
Computer POST and beep codeswww.computerhope.com/beep.htmHelp and support with troubleshooting computer beep codes and other POST related issues.
PC Hell: BIOS Error Beep Codeswww.pchell.com/hardware/beepcodes.shtmlPhoenix BIOS Beep Codes These audio codes are a little more detailed then the AMI codes. This BIOS emits three sets of beeps. For example, 1 -pause- 3 -pause 3 -pause.
beep codes Definition from PC Magazine Encyclopediawww.pcmag.com > Tips > EncyclopediaPC Magazine Tech Encyclopedia Index - Definitions on common technical and computer related terms.
How to Figure Out Why Your PC is Beeping (Beep Codes)pcsupport.about.com > Troubleshooting Guides > Symptoms2015-10-07 · Video embedded · How To Troubleshoot Beep Codes. Is Your Computer Beeping? Here's What to Do. By Tim Fisher. PC Support Expert Share Pin Tweet ...
Jan 23, 2016 | Computers & Internet
What does the flickering heart mean on the monitor?
According to http://www.omron-healthcare.com/data/catalog/3/188/1/IM-HEM-6000-E-01-08-08-EN.pdf it means you have the device in the correct position and it is starting to take a measurement - you should leave it until it completes. I am unsure if this is the correct model however:
"If your wrist is too low or too high, the position sensor alarm will emit a series of two short bleeps similar to a heartbeat.
When your wrist is at the correct position, the heart symbol
starts to blink and longer beep tones are emitted.
Sit still and do not talk or move until the measurement is
completed.
Keep the monitor at heart height until the measurement is
completed.
To stop measurement, press the O/I START button at any
time during measurement."
Nov 24, 2014 | Omron Health & Beauty
6 beeps what dose it means
Dell beep codes:
If your computer beeps during start-up:
Run Dell Diagnostics to identify a more serious cause.
Beep Codes Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3-1) consists of one beep, a burst of three beeps, and then one beep. This beep code tells you that the computer encountered a memory problem.
Contact Dell for technical assistance.
Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM read/write failure 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer failure 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3 Video Memory test failure 1-3-1 through 2-4-4 Memory not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller test failure 3-3-1 NVRAM power loss 3-3-2 Invalid NVRAM configuration 3-3-4 Video Memory test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No timer tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math-coprocessor test failure 4-4-4 Cache test failure
Aug 12, 2013 | Dell Gx620 Gx 620 Sff P4 Ht 2.8ghz 1gb...
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
When I turn on my dell 9200, a beeping sound starts from the CPU and nothing comes up on the screen
how many beeps you have?if three short beeps its you RAM failure..try to reinsert you RAM or replaced it a new RAM..if theres a long beep..its your video card..
Jul 27, 2011 | Dell Dimension 9200 PC Desktop
Everytime i start up the computer it beeps 3-4 times, and the monitor says vga input not connected...whats could be the problem?
here are the beep codes for your exact dell model. this should give you a starting point on finding out what the problem is.
Reseating the memory modules may fix the beep code errors in the following table. If the problem persists, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-3-1 through 2-4-4
4-3-1
If you hear one of the following beep codes, see "Contacting Dell" in your Owner's Manual for instructions on obtaining technical assistance.
Code
Cause
1-1-2
1-1-3
NVRAM
1-1-4
1-2-1
1-2-2
1-2-3
3-1-1
3-1-2
3-1-3
3-1-4
3-2-2
3-2-4
Keyboard Controller Test failure
3-3-1
NVRAM power loss
3-3-2
NVRAM configuration
3-3-4
Video Memory Test failure
3-4-1
3-4-2
3-4-3
4-2-1
No time tick
4-2-2
Shutdown failure
4-2-3
Gate A20 failure
4-2-4
4-3-3
4-3-4
4-4-1
4-4-4
Cache test failure
Jan 01, 2011 | Dell Dimension 4600 PC Desktop
At system startup the computer emit: 1 long beep and 3 short beep. Never appear to the screen. Could be a cpu problem??
The error code tells us that the video card is faulty, replace the video card, if the problem persists the mainboard is faulty.
Dec 28, 2010 | Computers & Internet
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
I get 1 beeb followed by 3 beebs followed by 2 beebs then nothng happens dell diemension 8400
Your computer might emit a series of beeps during start-up if the monitor cannot display errors or problems. This series of beeps, called a beep code, identifies a problem. One possible beep code (code 1-3) consists of one beep, a burst of three beeps. This beep code tells you that the computer encountered a memory problem
you need to reseat your memmry modules just remove them and place them back in the same or a diffrant slot this cold be loose connection by connecting them again you fix it
------------------------------------------------------------ if you dnt know abt it see this it will help you
http://support.dell.com/support/edocs/systems/dim8400/sm/parts.htm#wp1052406
Apr 10, 2010 | Dell Dimension 8400 PC Desktop
Turn it on it beeps cdc
You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
BIOS Beep Sound core list
AWARD BIOS
1 short(Beep) System booting is normally.
2 short(Beep) CMOS setting error
1 long - 1 short(Beep) DRAM ERROR
1 long - 2 short(Beep) Display card or monitor connected error
1 long - 3 short(Beep) Keyboard Error
1 long - 9 short(Beep) ROM Error
Long(Beep) continuous DRAM hasn't inset correctly.
Short(Beep) continuous POWER supply has problem.
AMI BIOS
1 short(Beep) DRAM Flash Error
2 short(Beep) DRAM ECC Check Error
3 short(Beep) DRAM Detect Fail
5 short(Beep) CPU Error
6 short(Beep) Keyboard Error
8 short(Beep) Display card memory Error
1 long - 3 short(Beep) DRAM Damage
1 long - 8 short(Beep) Display card or monitor connected error
Jul 16, 2009 | E-Machines T6520 PC Desktop
ASUS A8N-E Motherboard Logo
210 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
