My washer is leaking water from the bottom of the machine - what could be the matter. I cannot spend a lot of money to fix it - is there anything that I can to do fix it besides paying an expensive repairman?
  • 51 Answers
Http://www.repairclinic.com/0088_11_1.asp#Level2_19
Ask the Repair Clinic, he has three pages of answers for a leaking washer.
Posted on May 10, 2009
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Mar 22, 2017 | LG Tromm Front Load Washer And Dryer Set
Should I buy a new washer? I have a great Kenmore, Heavy Duty, 70 Series, model 110, serial number C83193200. Yes, it was made in 1983 and now leaks water from the bottom front onto the floor.
It could be a dry rot hose or the pump could be leaking might be an easy fix it depends whether you want to repair it or spend allot of money on a new dryer are u pretty handy i could assist you on how to fix it .
Nov 24, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Electrolux front load washer leaks from soap drawer
This is a common problem with front loaders. Probably poor design.
Jun 23, 2017 | Electrolux AWF 1435 Front Load Washer
Whirlpool Gold Ultimate Care II washer is leaking oil and water. Water is not leaking from the hose connection but seems to be coming from bottom of washer, as is the oil. Is it dead?
never dead just depends how much time and money you want to spend
new pump $60.00 dollars
new coupling $22.00
new tub seal $15.00
transmission and tub seal $236.00
specialty tool spanner wrench $16.00
this is just parts if you decide to replace installing yourself
Jan 27, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer started making a noise about a month ago, kind of like change rattling in the bottom of the machine. Today the machine leaked water all over the laundry room and down the hall. It didn't come...
sounds like the water pump, is leaking or the rubber hose from the drum to the pump. its very hard for money to get thru the filter holes, of the drum to the pump
Dec 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F & P Intuitive. Error 131. What will this
131 error is 'repetitive Rotaty Position Sensor error'. It could be wiring, but more likely to be a problem with the RPS itself. It's not a huge job for a tech. Before spending any money, check under the machine and make sure that the inside of the cabinet hasn't had dirty/rusty water flung from the flywheel. If the cabinet is clean and there's no leaks from the small holes on the bottom of the flywheel it should be ok to fix. (Water leaks would be a terminal problem) Get a quote, but be aware that F&P machines can sometimes have a secondary fault which causes the primary problem!.....Good luck....Nomess
Jun 18, 2010 | Fisher and Paykel Washing Machines
The inside washing "cylinder" is detached from washing machine unit...can this be fixed?
Anything can be fixed- just a matter of how much money you want to spend doing it. Refer to the warranty as this part may be free if you pay an authorized svcr to fix it.
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Isnt extracting water on spin cycle
If the water in the tub just stays in the tub no matter what,then the water pump is most likely bad.If not ,there is a piece of clothing in the pump,witch has stopped the pump.Check the drain hose also,to make sure that the hose is not restricted with anything,or the hose is not crimped.I hope this answers you question,and if so,please let us know ,thank you.
Nov 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana LW7503 washer is leaking water out the bottom
sounds like a faulty hub andseal kit , heres the part number R9900552 just about a hundred bucks. the only thingnot included int he kit is a 3m sealant( water tight and always flexible), as well as a "SPANNER wrench to remove the center hub. as a technician i get 375 for the job, ifyou wantto attemp it does come with complete instructions as to how to install, but this one id reccomend a pro(sorry but hate to have oyu spend themoney and time yourself, and wind up breaking something else
Mar 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
