Lower loop thread falls out
The lower loop thread on my Kenmore over lock 2/3/4D machine falls out of the needle after 4-5 inches of stitching. It is threaded properly and on a lower tension number. I thought the lower tension would help to not pull the thread out of place. What do I do???
  • 51 Answers
1: try more tension
2: See if it is hanging on something and is breaking off.
3. The other treads maynot be threaded correctly and one is pulling on the lower loop thread.
Posted on May 10, 2009
The thread for the top needle just sews and loops onto the lower thread
I think you are saying that there is a loop showing on the bottom of the lower thread stitch. If the lower stitch looks correct and not bunching, you will need to change the tension on the upper stitch. Make sure that your threads are firmly inserted within the discs also before adjusting the tension. It doesn't take much to change the tension so take it slowly.
Dec 31, 2013 | Sewing Machines
The lower stitching on my machine is not consistant, why?
Wrong size needle or wrong type of thread for the weight or type of fabric. For instance, you should use smaller needle size for light weight fabrics.
Jan 15, 2013 | Sewing Machines
I have been using my serger then suddenly it would cut and not serge. I am still unable to thread the "green" right hand threader.
Apparently either you have no needle threaded to lock the stitch or both loopers aren't correctly threaded. You must thread your UPPER looper first (don't know what color yours is), LOWER looper next, RIGHT needle next and last the LEFT needle if you are using the 4 thread overlock stitch. It sounds like you are having trouble with your lower looper. Look for the lower looper threader to help you thread it. Your manual should show you a picture.
Aug 10, 2010 | Kenmore 16622 Mechanical Sewing Machine
I bought a White Family Rotary sewing machine made in 1909. While cleaning it up, I unscrewed part of the tension assembly on the face plate not knowing that these can be very difficult to get back...
  • Set up your sewing machine on a table with good lighting available. Plug in the electrical cord. Insert a new needle into the shaft on the needle bar and tighten the thumb screw to secure the needle. The needle bar is the area on the shaft where the assembly for the needle thumb screw is located.
  • Step 2 Thread your sewing machine according to the manufacturer's directions. This requires slipping the thread through various retaining and tensioning loops to allow for the proper drag while sewing. There is usually one loop at the top to go through first, then a second above the thread tension knob. Bring the thread into the tension knob area and pick up the loop of the tension wire. Bring the thread back to the next upper thread loop and then down to the needle bar where you thread the needle.
  • Step 3 Wind a bobbin with the thread that you intend to use. You may have to partially unthread your machine to do this. Make sure there is tension on the thread while you are winding it so that the thread winds properly. Insert the bobbin in the bobbin case and place it in the shuttle race then draw up the thread with the needle thread to prepare to sew. The shuttle race is located in the lower body of the machine under where the needle enters the throat plate.
  • Step 4 Cut a scrap of fabric from the fabric you intend to use for this project, at least 12 inches long and 4 inches wide. Double the thickness of your scrap by folding it in half lengthwise. Insert your scrap under the sewing foot and lower the foot into position. Sew a seam approximately 6 inches long then remove the scrap to check the stitches. If the stitches are loose on the bottom, adjust the tension knob to a higher number for more tension. This is done by turning the knob so that the indicator mark moves to a higher number. If the threads are loose on the top you will need to make the opposite maneuver.
  • Step 5 Sew more seams on your scrap, stopping to check your thread tension for your stitches until you have stitches on top and on bottom with no discernible looseness.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Jun 17, 2010 | White Sewing Sewing Machines
    Bobbin Thread is "birdnesting"
    Get out the manual and refer to the maintenance section for cleaning the machine.
    Especially the bobbin area. You want to make sure the area around the bobbin case is free of lint and thread.
    Use a new bobbin and re-thread the machine, with the presser foot UP.
    Install a new needle, again according to the directions in the manual. Installed incorrectly can lead to mis-stitching.
    If the problem persits, the timing may need adjusting.
    This should be done by the sewing machine tech for Kenmore.
    Sewusa.com has a guide for this in the repair section, but you could end up with more problems.
    Apr 29, 2010 | Kenmore 15202 Mechanical Sewing Machine
    Kenmore sewing machine #16227 needle thread making big loops on wrong side of fabric. Changed needle, cleaned, adjusted/readjusted and readjusted needle and bobbin tension. Will sew a decent stitch...
    It is most likely because you have it on a type of stitch but did not switch the didstance that you want the zig zag to be. Just change you stitch or your distance.
    Nov 20, 2009 | Kenmore Sewing Machines
    Sears Kenmore sewing machine model number 15358 tension issues
    #14 needle is way big for cotton napkin scrap. a #10 is good for most lightweight fabric. #14 is for sewing denim or levis, like that.
    the tension problems on almost all machines regardless of price usually fall on the upper tension. the lower bobbin tension is factory set and it's rare you should ever need to mess with it.
    if you have a drop in bobbin (top loading), tighten the adjustment screw all the way and then back it off 1/4 turn. if your machine uses a shuttle bobbin, tighten the adjustment screw all the way and then back it off in 1/4-turn increments until you can hold it in the air like a yo-yo and cause to bobbin case to fall slightly dipping your hand.
    A dull needle and stitch length will also mess up your stitch. The idea is to narrow the problem down to one thing and one thing only -- UPPER THREAD TENSION.
    So, if you have the right size needle for the job, with the right thread, and if your stitch length selection is correct (usually between 2 and 3 or 8-to-10 stitches per inch, the problem should be with your upper thread tension.
    An easy way to fix this then is to remember: Loops on top, upper tension drop. Loops below, upper tension grow. If you get loops on top of your work, lower (drop) your upper thread tension to a lower number. If you get loops on the bottom, raise the upper thread tension.
    Different stitches on the same machine will require different upper thread tension settings. Don't be afraid of it. Just remember the pneumonic: loops on top, tension drop, loops below, tension grow -- referring to upper thread tension.
    have fun :)
    Apr 15, 2009 | Sewing Machines
    Thread continually breaking in lower looper needle
    I was having this very same problem with my lower looper . I had been using the one needle stitching all afternoon and I was doing quite nice stitching. then I decided to put the right needle back in and do some overlock stitching and guess what I spent the next two hours fighting the looper problem. I had completely re-thread this machine at least 20 times now. I decided to take the needle out and re-insert it and re-thread it one more time (right lower looper- then upper looper- right needle- then left needle) was careful to pull all threads to the back and under the presser foot for about 6 inches.
    Held on to the thread, lowered presser foot and did the chaining stitch. BINGO it didn't break, tried it with a piece of cloth and Perfect stitches. I have a Babylock BL402 and used tension settings left to right
    4-3-3-3 and default settings for the rest.
    Hope this helps someone someday.
    Jo Griffith
    Oct 20, 2008 | Toyota TL-432DE Mechanical Sewing Machine
    Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
    I have just learned this :)
    Either needle thread may be engaged for 2-thread serging.
    1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
    2. Rotate the handwheel to bring the upper looper to its lowest position.
    3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
    4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
    stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
    Those are for a flatlock stitch - for a 2-thread rolled edge :
    Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
    Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
    If you have any questions, e-mail me at knowgodnofear@bex.net
    Aug 10, 2008 | Baby Lock Eclipse Serger
    Washing Machines Logo
    47 people viewed this question
    Top Washing Machines Experts
