Question about Home Security
NO SOUND ON JENSEN RCS 70 BACK-UP CAMERA-BLACK AND WHITE-1999?
I'M NOT RECEIVING ANY SOUND AT ALL FROM THE CAMERA. I WAS THINKING IT MIGHT HAVE THE LITTLE HOLE ,WHERE THE SOUND COMES THRU, MIGHT BE PLUGGED WITH DIRT, BUT NOT SURE HOW TO OPEN THE CASE TO CK IT. ANYONE HAVE ANY SUGGESTIONS ? ALSO THE PICTURE COULD BE A LITTLE BRIGHTER. I HAVE TRIED THE CONTRAST & DAY/NIGHT CONTROLS IT HELPS SOME BUT COULD BE BRIGHTER, I THINK.
SOURCE: black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Posted on Aug 03, 2007
vijayanuda
  • 4 Answers
SOURCE: DVD playback in black and white
check colour system on both . if u dont know the colour system change it on AUTO.this will solve your problem
Posted on Dec 28, 2007
t00nz
  • 4738 Answers
SOURCE: when in the camera shoot mode the screen is black
test
Posted on Oct 08, 2009
t00nz
  • 4738 Answers
SOURCE: It appears that pictures are being taken with the
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Posted on Jan 21, 2010
  • 8457 Answers
SOURCE: We can't turn on the TV. We[ve tried the remote
The power LED indication light flashes or totally dead?The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Posted on Oct 17, 2010
Receiving only black and white
How do you have this hooked up, sounds like you have standard video plugged into one of the HDMI inputs that will cause a b/w pic
Mar 27, 2014 | LG 32LG30 32 in. LCD HDTV
How can i get to black and white mode, and take the time stamp off
The S6100 doesn't have a black-and-white mode as such. You could use the black-and-white copy mode, which is designed to copy whiteboards or print on paper ("Black and white copy", page 70). In addition, you can convert pictures to black-and-white using filter effects in the playback menu ("Filter Effects", page 122).
To turn off the time stamp, tap the bottom tab, tap the wrench icon, then tap "Date". Select "Off" ("Print Date", page 157).
The page numbers are in my copy of the manual. If you need a manual, you can download one from
http://support.nikonusa.com/app/answers/detail/a_id/17246
Aug 28, 2011 | Nikon S6100 Digital Camera with 28mm lens
I dont know what batteries to use and film to use on my minolta maxxum 70.
The Maxxum 70 uses two 3V CR2 lithium batteries.
The Maxxum 70 can use almost any 35mm film. Color prints, color slides, black-and-white prints. Do NOT use Polaroid instant film or infrared film.
If you need a manual, you can download one at
http://ca.konicaminolta.com/support/manuals/film-cameras/film_af_slr/dynax_60/Dynax_60_Maxxum_70_E_B.pdf
Jan 26, 2011 | Minolta Maxxum 70 QD 35mm SLR Camera
Our Jensen has no color. We have picture and sound, but in black and white. The display settings on the screen are in color. Anything I can do? The model is TS2750J. It's only 2 years old!
There are different types of color settings and systems - NTSC, PAL and SECAM. Are you sure the correct one is selected ? If yes then the problem is in the decoder and must be replaced since the chip cannot be fixed. This is a job for a pro.
Jun 27, 2010 | Jensen Q2749J 27" TV
DVD plugged into red, white and green(Yellow) TV imputs, results
Yeah no color coz its black and white. Color coding commonly yellow wire for video, red and white wire for audio. It should also be from DVD to TV, video out and audio out going to video in and audio in. And switch the TV to play video and the audio inputted. Maybe TV/Video Switch or button.
Hope it helps
Apr 06, 2009 | Jensen TS2750J TV
Jensen Bass Boost CR220x
white/black is speaker positive
white solid is speaker ground front and back ground
gray/black is speaker ground front and back
the solid black wire is battery ground
Apr 13, 2008 | Jensen SCR-60 Stereo Cassette Player with...
Plasma no picture, fades to black from startup logo
UPDATE:
I finally isolated the problem, the problem has to do with the Y SUSTAINER BOARD not receiving enough/necessary voltage when turned on, while initially thinking it was just the yboard was the problem, i replaced the Y sus board with no success, with only further diagnosis, i discovered the board voltages coming from the powersupply, there are 5 voltages that relate to the Y sustainer board, VA, VSC, VS, VE, VSET. they all supply a certain voltages that all have to be supply the correct voltage in order for the y sustainer board to be working, well guess what, the VA line, which for my set needs 70volts, which upon startup quickly drops from 75volts to a jumpy 8.5-9.5 volts, which of course is nowhere near the 70 volts needed, so this quick drop in voltage is directly related to the screen fade upon startup, i found the problem now the real problem is finding a replacement power supply. hope this helsp anyone with similar issues.
Mar 02, 2008 | Dell W4201C 42 in. Plasma HDTV
Just bought a componant lead for my sons psp and have vision but no sound. any ideas please
yes are using digital cable for sound going in or red white rcs ? in psp cheak audio out settings also ok
Feb 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Dec 28, 2007 | Jensen TS2050J 20" TV
Home Security Logo
241 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
