Question about Intel D865GRH (KD865GRHLKPAK10) Motherboard
Intel D865grh standby light on motherboard comes on. Power button will not boot up system. Power supply works fine in self test. System use to boot. Who can I test the system to identify the problem?
  • 1 more comment
  • mad4cmd May 19, 2009
    Thanks , I have tried this, no difference. How can I tell if BIOS is running, prior to the power supply turning on? I pulled the jumper to re-install BIOS and still nothing. I have ordered a new Motherboard. Would still like to solve this one's problem. Thanks for your insite. Mark
  • mad4cmd May 28, 2009
    Problem still there with new motherboard. At first this tells me the problem is not the motherboard. But P.S. bench test good on all voltages, Processor and Ram run fine in other machine, AGC works and front panel on sw works. J9J1 pin 6 goes low but Main P.S. connector pin 14 (PS_ON) stays high and P.S. won't turn on.
    I have tried another P.S. What is the best way to bench test the D865grh Motherboard? mad4cmd
    I believe so. I have tried three sets. The one on board now, I removed from a working compatible computer.
  • 272 Answers
First check the RAM. please remove and place tightly again. Try it and if fails, comment here for next step .
Thanks
Posted on May 10, 2009
  • Fixer May 28, 2009
    are the rams ok ?
    next what comes, the graphics card issue. do u have adden one or the one built in ?
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Intel dx 58 so board with i7 930 no boot no beep intel send me new board but the problem is same with new board
Intel sent you a new board, so it's probably not the board that's at fault. The next thing to try should be a new power supply. Just because the system turns on when you press the power button, it does not mean the supply is working properly. You may be able to borrow a supply for testing. Then try a new processor IC if the trouble continues.
Aug 04, 2011 | Intel DX58SO Motherboard
CPU: intel core i3 550, MB: Inel DH55TC, Ram: Transcend: 2GB 1333Mhz, SMPS: 550 Watt. After first installation, this system ran for 3 months without any problems, suddenly, it became dead and assuming it...
How many years do you own that desktop computer? You have a problem with your Ram: Transcend: 2GB 1333 Mhz
Ram is always responsible to boot and run all system required by your computer
A defect ram cannot boot or not properly run application e.g.
Power-On-Self-Test (start up of your computer)
Booting your Operating System
Running your Application like Microsoft office , Photoshop and so on
Replace your Ram
Jul 25, 2011 | Intel DH55TC Motherboard
No graphics software and audio drivers for system model d865grh
This is the driver page for that chipset:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+865+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D865GRH
If the drivers exist, they will either be on that page, or Windows will automatically fetch them given you have an internet connection. Generally, Windows can utilize generic drivers for graphics and audio int he event proprietary ones are not installed, and you should be able to use the computer just fine.
Dec 20, 2010 | Intel D865GRH (KD865GRHLKPAK10)...
Intel D815EEA2 mobo won't boot - no clue to why not.
I know, this is a very frustrating situation...
Unfortunately, the only reasonable way to find out what's wrong is to swap components with a reference system, until you found the defective part. I hope you have another P3 system available to swap parts.
I would do it this way:
  • First check that the power button is connected correctly.
  • Swap the memory from the faulty system to the reference system.
  • If ok, put it back into the faulty system and connect the power supply from the reference system (or some other known good one) to the faulty system.
  • If this doensn't help, swap the CPU from the faulty system to the reference system.
  • If the CPU is ok, the motherboard seems to be defective.
Mar 24, 2010 | Intel Desktop Board D815EEA2 Motherboard
I have the A770E motherboard with the AMD Phenom X4 cpu. It works fine till I turned my unit off last night and then in the morning tried to turn it back on and it couldn't re-boot it self. What can i do?
As with all motherboard troubles testing for an issue means trying one thing at a time.
On the back side of the power supply is a little switch. Currently this switch is set to ON, flip it to off. Open you're case and find the cmos two pin jumper. Check you're manual, see page 16. Follow instructions to clear the bios. While you're case is opened re-check all power cables from the power supply to motherboard.
Flip the power supplies switch to the on position. Try booting up you're system. Listen closely for, POST = Power On Self Test. By clearing the bios you set the bios to its default settings. If you’re system still doesn’t boot than again power off the power supply. Try removing all memory except DIMMA_1 and DIMMB_1. (See page 9). If the memory being used is not dual channel remove all but one, (DIMMA_1) memory stick. Switch the power supply switch back to on and boot the system. If you’re system boots than there might be a problem with the system memory. You can download memory testing software at http://www.memtest.org/ Memtest86+ V4.00 (22/09/2009).
Try the above and get back to me by adding to this question.
Cheers’
Mike
Feb 13, 2010 | Biostar A770 A2+ Motherboard - v6.0, AMD...
My mb is m2n32sli dlx wireless edition it is just dead want give any beep,led on mb is coming on but no display,my graphic card is working fine on another pc,my prosser is also working.i check all ddr2 667...
have you tried testing it with a diff power supply? the power supply may be working but its not giving the motherboad with sufficient current to run, you have tested the other parts and they all work fine but you have not yet tested your power supply, or test you power supply to other system see if it will boot other system or vice versa
Nov 20, 2009 | ASUS AI Lifestylestyle M2N32-SLI...
Intel Desktop Board D945GNTLKR did not boot
Try choosing the 'Exit Without Saving' option in the BIOS menu. If this kicks you to the boot media search, then 99.99% the BIOS is corupt. If not, try to replace the CPU cooler (don't forget to apply the thermal grease).
Mar 15, 2009 | Intel Computers & Internet
DG31PR Won't Boot
you ight have a BAD CPU, try checking it out on another pc or friends pc.
Jan 08, 2009 | Intel DG31PR Motherboard
**System randomly hangs**
Electrolytic Capacitor Failure on some Intel mobo. Products Affected:
Intelreg.gif Desktop Boards D865GBF, D875BZL, D865GLC, D845EPI, D865PERC, D865GRH, D865PERL, D845GVSR, D865PESO, D845GLVA, D865GWV, and Intelreg.gif Entry Server Board S875WP1-E.
Should replace the capacitors shown in the photo attached. 73d0b16c-0d36-4176-be42-6dd73b32fb65.jpg
Oct 24, 2008 | Intel D865GBF Motherboard
Intel D865GRH (KD865GRHLKPAK10) Motherboard Logo
209 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
