Question about HP Photosmart M425 Digital Camera
Lens will not come out
Camera will turn on but the lens will not come out.  The batteries are new. I have removed the memory card, taken out the batteries for 15 seconds.  There is no change.
  • plzsos Dec 23, 2007
    when i turn on camera, the lens and thing that comes out i think the shotter will not come out all the way plz someone help me!!!!!!!!!!!!!!!!!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Sep 08, 2012
4 Suggested Answers
Dinoza
  • 112 Answers
SOURCE: camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Posted on May 01, 2007
  • 155 Answers
SOURCE: when i insert the memory card the camera freezes.
It sounds as if either the file allocation table or some data on the card has become corrupted.
Have you got access to another camera (friends or family) that you could try it in?
Have you got a card reader on your PC? If so, you should be able to re-format the card using Windows. (Go to My Computer, right-click on the card reader icon and select format)
Hopefully this will cure the problem. If not, you should be able to change it if it is new.
Matt
Posted on Feb 27, 2008
jigsawbill
  • 398 Answers
SOURCE: Can't take pictures, camera says it's in DOCKING mode
It sounds like you may have filled the memory car with pictures, and to continue to use it you must delete those which are on the card. I download my pictures to the computer and then I can delete them from the card and start all over again with taking pictures. I may have misunderstood your problem, if so please excuse me!
Posted on Sep 04, 2008
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
When i turn the camera on it says lens error
There are 2 fixes I know for this you can try.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. You don't have a memory card installed, so turn it off, slip in the sd card and turn it on one last time.
Jun 07, 2010 | Nikon COOLPIX L18 Digital Camera
Lens error
May 31, 2010 | Nikon Coolpix S210 Digital Camera
Lens wil not open. Turn camera on and it gives you a "lens error"
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Thank you !!
May 26, 2010 | Nikon Coolpix 2100 Digital Camera
Lens error
2.
Thank you !!
May 23, 2010 | Nikon COOLPIX L18 Digital Camera
Powers on, lens extends, 3 beeps, lens closes, camera turns off
Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think the camera was getting hung up on the pictures stored in the camera's memory.
Aug 17, 2009 | Cameras
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Camera freezing
try a new memory card. also try to reformat the memory card. dont take images you care about until resolved.
i would try to remove the battery for about 10 seconds, and then reinstall, then reformat the memory card. if you still have the same issues, replace the memory card. it that does not cure it, you have a warranty repair to manage.
good luck
mark
Dec 23, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Camera lens
My camera did the same thing. Try doing a couple of things.
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (not sure if this helps, but it worked for me)
I think for some reason my camera was getting hung up on the pictures stored in the camera's memory.
Nov 16, 2007 | Cameras
HP Photosmart M425 Digital Camera Logo
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
