Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
Pioneer 640H-S REPAIR on display
I have not been able to do anything since the power went out (and back on). It has not returned to normal... It has been 4 hours since it has done this and I can't get it back. I really would appreciate help in resolving this issue. I have tried doing the Stop & Power button, but nothing happened at all.
If it is at all possible I would like to keep using this product!
  • 2 more comments
  • ceskepivo May 10, 2009
    This is not the issue. The device is on. It is posting Repairing the HDD on the screen and REPAIR in the display on the console.
    The issue was caused by the power outage. It seems to not want to repair the HDD. The troubleshooting section of the manual says this is normal but what I do not think is normal is how long it has been in this state. Again it is a Pioneer 640H-S DVR/DVD recorder and I am not wanting to lose this functionality
    Anyone have any suggestions how to fix this Repairing the HDD error message?
    The manual does not state anything about it except that it is repairing the HDD. No info on how long, or what to do if it stays this way...
  • 3,267 Answers
Since your power input circuit has not been affected, but the HDD as reported in the error message means the power supply is ok, but only for voltages of 12V & above. This can be cause
1. The lower voltage of 5V may be damaged, which is used to read/record from the HDD.
2. The HDD has got corrupted!
The simplest way to start is first remove the HDD, power on your DVR-640H and notice the error message that should appear on the Display. Reinsert the HDD and again power on. If the earlier message reappears, then the power supply to the HDD voltages need to be measured by a multimeter. If you find that the 5V supply is not correct, then replace the transformer in the power supply circuit
However if the voltages are proper, then try connecting the HDD to a PC via the USB port. Run the checkdisc from the PC. Bad sectors are bound to come & if it does not execute the format command for this HDD, then it indicates bad many sectors which the software is unable to fix. But if it does rectify the HDD and is now formatted, replace it in the DVR and try. If the error message does not appear start using it as if its a new item.
However most probably the HDD rquires replacement is the first method fails. I am you must have gone through the manual which says "• The HDD is very delicate. If used
improperly or in an unsuitable
environment, it is possible that the HDD
will fail after a few years of use. Signs of
problems include playback unexpectedly
freezing and noticeable block noise
(mosaic) in the picture. However,
sometimes there will be no warning
signs of HDD failure. If the HDD fails, no
playback of recorded material will be
possible. In this case it will be necessary
to replace the HDD unit.
Optimizing HDD performance
As you record and edit material on the HDD,
the data on the disk becomes fragmented,
eventually affecting the recorder’s
performance. Before this happens, the
recorder will warn you that it is time to
optimize the HDD (which you can do from
the Disc Setup menu; see
Optimize HDD
on
page 105).
Its extremely delicate and if the voltage supply to the HDD is OK you have no alternative. Just replace the HDD with a new one(but my instinct points to improper lower voltage supply)
............................sodeep
Posted on May 11, 2009
  • 413 Answers
  • 854 Answers
• Make sure the power cord is plugged in.
• Try another AC outlet.
• Power is off, check fuse or circuit breaker.
• Unplug unit, then plug it back in.
• Select the DVD or VCR mode before operating.
• Antenna connection is not correct or antenna cable is disconnected.
• The video channel is not in the correct position or the TV is not set to the
video channel 3 or 4.
• Check the unit is connected correctly.
• The video input selector of the TV is not set to VIDEO. Set to VIDEO (or
equivalent).
• Channel is set to the external mode
Posted on May 10, 2009
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Front lamp flashes on and off but machine wont work. machine will work when power cable turned off then back on.
Hi
I do not know this model, however, it sounds like a common problem which has occurred on similar models where some capacitors fail on the secondary part of the power supply, 3 or 4 1000uf capacitors fail. The machine needs to be serviced as if this is the issue the problem will continue to get progressively worse. You will find that the times it will switch on fully will diminish.
Regards
TechSupp12
Dec 12, 2010 | Pioneer DVR-640H DVD Recorder/HDD Recorder
It displays muting in the lcd box how do i get it back to a normal state ?
Press the "Mute" button on the receivers remote control again and it will return to it's normal state. Hope this helps.
Sep 26, 2009 | Pioneer VSX-305 Receiver
"could not repair disc" after power outage
If this happened after a power outage and not a hit/drop then it's probably fried the board to the hard disk, you can often get another board from the same model drive and fix it, by swapping the boards over.
May 25, 2009 | Pioneer DVR-640H DVD Recorder/HDD Recorder
What kind of remote i can use for pioneer dvr660
I can find of no compatible remote for this item! but if you go to www.remotes.com they may very well be able to get you an orignal remote for your item!
I hope this will fix ya!
Please use ratings
THANK YOU!
Jan 12, 2009 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Wrong region code
You have to unlock it somehow but i would suggest you return it to the shop and ask
Nov 01, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Movie regions
Go to: www.videohelp.com what you are looking for is a region free hack..put your machines numbers in, hit search, scroll down, look to right of screen to see if a hack is listed.
Jun 26, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
336 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
