Question about Acer Aspire 3680 Laptop
Internet connection switch does not on automatically
Nuttoneed to use one hand at the switch and one had puch the power
botton and also at sign in after shut off once and turn on again.
Driver all
Posted on May 11, 2009
NO POWER AND NO DISPLAY
try without battary......
otherways... disconnect power jack and battary and all other cable connected to computer and press and hold power butten for 38 sec then try to power on
Nov 25, 2012 | Compaq Presario C700 Series Laptop...
Maytag performa dryer wont start - probably thermal fuse right? checked door, breaker, plug, ect.. When puch in the botton to start i can hear a low humming so im sure the motor is working
The problem is likely with the centrifugal switch on the dryer motor. This switch connects the start winding of the motor which provides additional torque at startup. Once the dryer is up to speed, the switch disconnects the start winding. If it malfunctions, the dryer will not turn and the motor will hum. By spinning the drum, you are providing enough torque for the start winding to be able to take over and bring the dryer up to speed.
You may be able to solve this if you can lubricate the centrifugal switch with a spray lubricant. If not, you may have to replace the motor. I do not know if the centrifugal switch assembly can be replaced.
Nov 28, 2010 | Dryers
I can not get my key out of the ignition. It will
take it all apart with the key in itand replce it for a new switch they are only like 30 dollars that one got is broke when you take all apart right under the switch you will have to puch a botton with a screw driver to pull the old switch out
Jun 14, 2010 | 2006 Chevrolet Cobalt
I try to connect to yahoo messenger and I get a message that says there might be a problem with your internet connection, i run the trouble shooter in this message and it says possible problem with http...
Right click on your internet connection logo (2 blue monitor screens) in the System Tray and select "Diagnose and Repair"
No Problem? proceed.
Internet Explorer is used to sign into Yahoo Messenger. If you have another browser set as default IE will still sit as a link between your browser and Yahoo Messenger. For this reason most troubleshooting is concentrated on Internet Explorer.
Try each of these in turn, and try to sign in after each of them - if successful (or not) please feed back information to help others.
1) I would recommend installing the latest version of IE and update any support software (Flashplayer, Java, Shockwaveplayer) for IE by using an update checker
http://www.filehippo.com/updatechecker/
2) Start with a clean browser
Download 'ccleaner' and run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.
http://www.filehippo.com/download_ccleaner/
3) On the sign in page click 'Messenger' > Connection Preference
Toggle between 'Connect direct to the internet' and 'Proxy setting' make sure the information is correct in the lower 2 boxes. I am currently in the Asia Pacific region and I have to toggle between these settings a few times a week to maintain my connection
4) Check these settings in IE (even if you have another browser set as default)
a) Tools > Internet options > Connections > Lan settings > check 'Automatically detect settings - uncheck other options.
b) Tools > work offline - make sure this is NOT checked and has a red X through it
5) Disable your firewall and do a trial sign in
6) Control Panel > Internet Options > Connections > LAN Settings-uncheck Proxy server and check automatically detect setting
7) Control Panel > Internet Options > Connections > dial-up and virtual private Network setting > select your default connection > setting > check automatically detect setting
8)If you are unable to sign into this secure page (https)
https://login.yahoo.com/config/login?.src=fptx._intl=uk
copy the yahoo https address above and paste it in here:-
IE > tools > internet options > LAN settings - check automatically detect settings > Advanced - paste in 'Secure' window > OK
9) Run ccleaner again
Feb 10, 2010 | Yahoo Messenger
Cannot login
try the forgot password, even if you know the password, it will help you with all the details, and you might be able to reset the password.
Feb 04, 2010 | Yahoo Messenger
Trobleshooting when i sign in yahoo messenger???
the sign in did not connect in  time basicly the internet connection was not active that's way you get a window that say troubleshooting or cancel.
Feb 01, 2010 | Yahoo Messenger
Iam using yahoo messenger10.0 but when i sign in
i advice you to reinstal the program maybe you did something wrong during instalation.
Jan 14, 2010 | Yahoo Messenger
Internet explorer is not working properly
di u setup the connection ?
else do this..
open Explorer..in the menu Tools/internet options/Connection Tab/
next u can either setup the new connection or if ur using a broadband/DSL cable and connect using a LAN port check the Lan setting at the botton of that window
if u want to use setup option
click Setup/Next/Connect to Internet/Setup my Connection Manually/Conenct using my boradband connection that's always on....
if u want to use LAN setting do this
Click LANsetting/Check the box "Automatically detect setting"
OK
Let's c if this works else we will work on some other solution...
Dec 20, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
N 70
try to HARD RESET FORMAT
make sure your battery is more than 3bars,
just press the green botton, 3 ,* and power botton at the same time.
Don't release it until you see the Nokia blink and the screen turn on white' and then release all the botton you press.
wait untill your phone re-boot.
hope it will fiya your prob.
thanks for rating this solution.:D
Mar 11, 2008 | Nokia N70 Cellular Phone
Acer Aspire 3680 Laptop Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
