Question about RCA F27678BC 27" TV
Trying to hook up DVD player. Cannot get a video display on TV
To do menu startup of DVD player. Have tried putting TV on Channel 3 - no video display. Cannot locate any auxilary or video function on TV menu. Any suggestions?
  • 3 more comments
  • john_hariacz May 10, 2009
    there is no AV button on the remote only a sat/aux, tv/cable, tv/vcr
    I don't have a user manual. If I did, I would have referred to it, and not used this service.
    RCA TV MDL #F27678BC (built 3/98). Do not have manual nor original remote. Have RCA remote with sat/aux, tv/cable, and tv/vcr functions. Trying to hook-up dvd player. Cannot get a video display on tv screen. Cannot locate any video or aux options on tv. Have tried putting tv on channel 3 and 4 - no luck with getting a video display of dvd. Suggestions?
    You gave a good suggestion. I had another universal remote that I forgot that had an input feature. Tried it and it worked. Thanks for the excellent guidance to solve the problem.
    Yes, provided the solution that I was looking for.
  • 10,594 Answers
Your TV can be switched to DVD INPUT by RCA TV Remote only that has Input button for that.
Click HERE to get substitute remote for RCA TV as original remote is no longer available.
Thanks.
Posted on May 10, 2009
    President:
  • 2,923 Answers
Locate the AV button on your remote control. Then select AV1 if the DVD player is connected to the AV1 input on the back of the TV.
Select AV2 mode if the DVD player is connected to the AV2 input.
If you couldn't find the AV button on your remote control, you need to refer to the user manual of your TV and see the equivalent button for the AV.
Have a great day!
How do i program my tv too play dvd player
The TV remote should have a source button on it, you need to press it and find the scart socket or hdmi connection, it should display a list of the connection that are use for your TV. Some times you can use the power on on the DVD, so have your TV on then switch on the DVD and this may change the TV to the input that you have the DVD connected to automatic-lay. If you are using a TV arial for the DVD to connect to the TV then you need to tune the TV to the channel the TV is using I think in most cases it is channel 21 on the TV.
May 10, 2014 | Disney Lightning McQueen TV
F2-1000T Digital Set-top Box.
There are three ways you can connect a DVD player to a TV. Component video gives the best picture quality, but requires 3 cables for the video signal alone. S-video needs only 1 cable but it isn’t as good as component video. Composite video is the easiest connection to make, but gives the lowest picture quality.
Aug 05, 2008 | Televison & Video
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
Cannot get a clear picture with dish network I have a Clear picture when using DVD
Sometimes the input/channel for the DISH Network and the DVD are different, and if using the same for both, then you will get an unclear picture on one. If at TV1, the tv will need to be on channel 3 or 4, and possibly an input such as video 1 or 2. The DVD player may be on a different input, such as video 3, or even just on channel 3 only. If at TV2, the tv needs to on channel 60 or 73. When using the DVD, try putting the tv on channel 3 or 4, that is normally the channel that the tv needs to be on. Also, make sure that the DVD player is not on while you are trying to watch just the dish.
Becki Barned
DISH Network Customer Service
Dec 03, 2010 | Apex Digital LD4088 LCD TV
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
RCA F32450 TV can not get the TV to display the DVD menu
You can get a remote from Electronicadventure.us for $29.95. The remote number you are looking for is RCA-GE-PROSCAN 242524
Nov 15, 2008 | RCA F32650 32" TV
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
It does not display or play
You have to run a search of available channels on the DVD recorder through the setup menu. After the recorder has located all available channels, make sure the TV is on the correct input. (Video 1, Video 2 or whatever)
If all else fails, then read the manual. HaHa
Dec 29, 2007 | Philips Magnavox MWR10D6 DVD Recorder
Televison & Video Logo
223 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
