Question about Refrigerators
Dometic rm2611 not restart after cooling box normally, then warmi
Performed rebuild of dometic rm2611, 921 57 11-01, including rebuilt cooling coil, new re-ignitor, thermocouple, new circuit board and new display. refer starts and cools great, and shuts off gas upon reaching cool temp in box and freezer. will not restart automatically after warming to re-start temp. if refer turned off manually, and then turned on, re-starts without hesitation. thermistor not replaced
  • 2 more comments
  • dhschultz39 May 11, 2009
    placed new thermistor on order today, but since it's an analog device, don't expect a new one to do the trick. removed gas valve already, cleaned with MEK (no evidence of contamination), and cycled numerous times with 12 v source. functioned perfectly a dozen times.
    re-ignitor is not firing when demand for cooling is initiated (after refer cycles off, change set temp on display panel to colder) - if ignitor not seeing 12 volts, gas valve doesn't see 12 volts.
  • dhschultz39 May 13, 2009
    thermistor replaced with new one on 5/12/09, tested over-night - same result this morning. i.e., refer had cooled normally (melted ice on freezer tray), but not restarted, and "check lite" on. turned refer off, then in 15 sec back on. refer started normally, and is cooling now. obtw - gas valve still cycles normally with external 12 volts applied.
    thanks for input, but in response to your sol'n, camper is on a level, roller cart, stored in a shop in seattle, wa. outside temp is ave 45 degrees, and thru all testing have had camper side cover over refer removed. don't think outside temp is a problem.
    obtw - replaced thermistor yesterday with new, and as suspected, no difference in symptons; i.e., started normally, cooled, shut off, and then illuminated the check lite when restart called for due to rising temp in the box. upon shutting refer off this morning, then turning on, refer started on first firing of re-ignitor, and is cooling normally now.
    i'm beginning to believe the new controller board is faulted - about 7 days old.
    r/s
  • dhschultz39 Jun 02, 2009
    tried second main control board (PPL Mtrhomes, Ron Hunt, in Texas, great about replacing electronic stuff), made no difference in symptoms. internet research revealed lots of problems with dometic boards. found supplier (dinosaur electronics, inc.; lincoln city, or.; tel: 541 994-4344) that produces board that eliminates problems of dometic board plus lots more + offers 3 yr guarantee. bought, installed, problem corrected. ($154 incl shipping and hdlg).
    fixya techs no help.
  • 15,935 Answers
Yes - your issue is definately the controller board... intermittant problem usually is from bad solder joints. Parts CAN fail directly out of the box - although highly unlikely.
Thanks for using FixYa
Posted on May 13, 2009
  • 413 Answers
Your fridge is working against outside air tempurature and any solar heating effect. To maximise the operation of your fridge allways try to park the unit so the fridge side will be in the shade. Do you have a fan to create the air circulation in the back of the fridge? There are kits available for this. I use a recovered converter fan and have it set up in the bottom of the fridge cavity below the coils and blowing straight up. This helps a lot. The kits normally come with a 80 degree F temp switch, I have a leftover toggel from some where for mine. I don't think your fridge is the problem. I don't think a new one will fix it. Your best bet is to do the kind of thing I have above and it should work better. Hopefully good enough. Good Luck
Posted on May 11, 2009
  • 163 Answers
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
Posted on May 10, 2009
DOMETIC RM2611 FREEZER WORKS BUT REFRIDGE IS NOT
move temp sensor lower on coil or let hang see if it changes
Apr 04, 2014 | Dometic Refrigerators
Dometic rm2611 freezer works fine on propane but fridge doesn't cool
move temp sensor to middle of coil if same replace temp sensor
Mar 28, 2014 | Dometic Refrigerators
Won't work on any power source
If the RV is level and the rear coils of the cooling unit are warm, then you will require a replacement cooling unit. Changing the cooling unit is something that can be done by the end user such as yourself. Check out Arcticold Cooling Units.here ArctiCold Refrigeration We keep it cold or give them a call toll free 1-888-782-6665
By replacing the cooling unit with an aftermarket one, it will save you you money (vs buying a new fridge) and increase the performance and durability of your fridge. Arcticold cooling units can be purchased on ebay Dometic RM2611 Brand New Manufactured Cooling Units LIFETIME WARRANTY... The RM 2611 cooling unit is the same as the RM2620 28c4e1ea-6951-42e3-827e-9b9809f394fb.jpg
Mar 09, 2014 | Dometic RM2620 Refrigerator
How to remove a dometic rm2611 refrigerator
remove cover from outside unplug AC and shut off gas remove line then unwire take picture first remove screws on bottom holding it in then remove trim on front top and bottom have screws remove
Jan 19, 2014 | Dometic Refrigerators
RECHARCHING MY DOMETIC RM2611
Hi, it is not as simple as recharging when it comes to an RV fridge. If you have lost your pressure then you need a replacement cooling unit. A Cooling unit can normally be changed in approximately 2 hours with no specialized tools needed. Our cooling units come standard with installation instructions. Arcticold cooling units are Bran NEW not rebuilt. Our Products are unmatched in quality and performance. Check us out
Jan 17, 2014 | Dometic Refrigerators
Recharging my dometic rm 2611
closed system replace cooling unit
Jan 17, 2014 | Dometic RM2620 Refrigerator
Dometic rm2611 quit on the road today all lights
If the fridge is complete dead (no lights no fan, no compresor,etc.) looks like there's not power in the unit.Check if theres power in the oulet if you know how , if you don't put the fridge in an oulet that you know is power , if still doing nothing probably the cord is broken or burned and the power doesn't go throught it from the oulet to the fridge.
Apr 27, 2009 | Dometic RM2620 Refrigerator
Refrigerators Logo
374 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
