Question about Toshiba Portege S100-S1133 Notebook
Battery doesn't work
Computer and battery were working fine - suddenly there's a power cut and i discover the battery doesn't cut in. When the power comes back i check the power meter which tells me the battery is fully charged. Toshiba power management says the same - battery fully charged, but nothing I can do will persuade the battery to work.
Tried testing the battery with a multimeter but couldn't get any reading.
Is there some fault with the power software/recharging facility I wonder?
  • jim_wrench Sep 07, 2008
    mine does the same thing but how can it be the adapter?
    it works when plugged into the wall fine and there is only one positive and one negative on the adapter
    Sergeant:
  • 457 Answers
Replace the adapter the power cut caused it to blow out......aways happens it is the power serge that cause the fault.
Posted on Oct 12, 2007
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
Battery indicator
tray by another charger if not. another battery if not working that will be the problem in motherboard u have to take it to service center good luke
May 17, 2013 | Computers & Internet
Radio doesn't work on batteries
same problem here, but with my radio shack scanner. When I disconnect the cord, however, the low battery indicator symbol comes on for a bit so radio seems to be taking in juice. May try a better brand of battery or some rechargeables.
Apr 30, 2013 | C. Crane SWP AMFM Radio
I have a 6 volt battery from 1 power wheels and want to put it in another power wheels because that battery doesn't work. They have different connectors though. Can I cut the connectors off the battery...
i would use some jumper wires with alligator clips on the end, just in case it isn't the battery that is the problem, otherwise it is safe to cut them, just don't cut through both of the wires at the same time cause it could cause the battery to short and when you're hooking it up to the new connector make sure that you get the polarity right(positive and negative)
May 01, 2012 | Toys
Unknown problem
I would say your battery is fine. What happened is the computer was running off the battery even though it recognized it was plugged in. There is a piece in the power jack that tells the laptop that you are plugged in, but it doesn't necessarily mean the adapter is working. I would have the adapter checked to be sure it's working before I suspected the battery.
Jan 08, 2010 | HP Televison & Video
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Toshiba Portege S100-S1133 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
