Question about Harvard Single Shootout Basketball Arcarde Game
The front legs on my game are bent. where can i find replacement parts? thanks!
    Sniper:
  • 75 Answers
This is the only place I could find which is direct from the manufacturer. short of making something yourself or scavenging from a broken unit that you may find on ebay one day I dont really see any other options.
http://www.escaladesports.com/customer-service/partsrequest.html
Posted on May 12, 2009
We are installing a dishwasher--have it hooked up but can't seem to get the leveling legs loose so we can adjust the height. Also, the anchoring peices of metal stick out farther than our countertop.
Hello, This dishwasher has the ability to be mounted to the cabinets on either side of the dishwasher.the mounting brackets can be moved to each side. If it must be mounted to the counter top, the mounting tabs can be bent by hand and it will break the front part of the mounting tab. This will shorten the mounting bracket. If you have granite counter tops do not attempt to drill into to the granite counter call a granite fabicator. The leveling feet are hexagon shaped at the top of the of the leveling leg. Remove the front lower toe kick panel. This will allow access to the top of the leveling legs,then use a small cresent wrench or a socket and rachet.Hope this helps.Joe Connolly
Sep 18, 2011 | Frigidaire FGHD2433K 24 in Builtin...
I dont know exactly what happened my buddy had my bike out and wrecked it .. Looks like the front wheel came back into the radiator. Its not in the radiator now. But I know something is bent because the...
The forks usually bend well before the frame.
Take the forks off the bike and turn the chrome part in the fork leg and you will soon see if they are bent.
If they are only slightly bent a dial gauge will help.
Dont even think about having them straightened, get new ones
Jul 17, 2011 | kawasaki ZZR 600 Motorcycles
I have a Mazda Midge 1998 whick was damaging the left CV joint regularly. After replacement of all suspension parts I diagnosed the problem to the gearbox. Drive and all the load is only on the left drive...
hj there this is perfectly normal because the left wheel is the drive wheel on a basic front wheel drive gearbox,Check if the shaft is not bent secondly inner CV TRIPOD could be worn. Left front chassis leg could have bent due to accident or impact .Outer CV my have been fitted incorrectly.
Aug 17, 2017 | Mazda MAZDA3 Cars & Trucks
Hello! I have own for like 15 years a Bogen tripod. Lately I have to tighten the legs screws very hard to keep them in place. How can I solve this? thanks, Luis
Depending upon the model of the tripod, the legs where ithe locks are may be bent, mis-shapen and need to either be replaced or rotated. It all depends upon the model since there are many different styles and some may not be repairable eother due to age or parts availability. Some of the digi series just are expensive enough to repair.
Apr 04, 2010 | Photography
I seem to have play in my front suspention leg what can i do ? Ibumped the wheel and dented it when i skidded in the snow do you think this could be the cause? thanks
It is out of alignment and has a bent steering rod and the rim is bent and out of round so it will need a connecting rod or tie rod end. they rim may not be able to be straightened ,so expect to have to replace it but don't know for sure. would have to see if. Most likely has a bent cross link it does not take much to bend them. so will need wheel alignment and wheel balance at a minimum.
Jan 19, 2010 | 2001 Ford Escort ZX2
Biscuit legs seem to be out. he can not sit. His legs are criscrossed
I pulled the skin back and the legs were bent inward. They are plastic framed legs and cannot be bent back into shape. Any thoughts on where to get replacement parts for him?
Jan 01, 2010 | Tiger Electronics FurReal My Lovin' Pup
Can i straighten the front forks up if I loosen the nut on the headstock, move the fork legs, and retighten the nut again? the bike is a VL800 k5.
Loosen the front fender, the axle retaining bolts, plus the upper and lower headstock bolts and nuts so that the whole assembly is free to align. Tighten the fender last. If that doesn't restore wheel alignment, you may have bent tubes that need straightening or replacement. Was the bike in a front-end wreck?
Nov 15, 2009 | 2005 Suzuki Boulevard C50
My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Oct 11, 2009 | KitchenAid K45SS Classic Stand Mixer
Front end trials bike
Hi, Jn_potter the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Jun 19, 2017 | 2008 Sherco 1.25 Enduro
Harvard Single Shootout Basketball Arcarde Game Logo
416 people viewed this question
Top Harvard Sport & Outdoor - Others Experts
Are you a Harvard Sport and Outdoor - Other Expert? Answer questions, earn points and help others
