Question about Kenmore 63942 Dryer
Money (change) caught inside interior drum plastic pieces.
There is change (money) caught inside plastic pieces of the interior drum. I was wondering if anyone knows how I can un-snap these pieces (3 of them) and then I can get the change out of them to stop the noise it makes as the drum rotates.
Dryer is a Sears Kenmore Elite Model # 110-70982990.
Thanks!
  • Kenmore Master
  • 3,361 Answers
Remove the top lid.
Rotate the drum until a vane is at the 12 o'clock position.
Remove the screws from the drum holding the vane in place.
Posted on May 10, 2009
I was defrosting frozen spinach in a plastic tub for ten minutes and inadvertently had it on full time! Spinach caught fire and tub melted totally down! Nothing is working on the microwave now. Is it...
The microwave oven is not worth sinking the money into, the interior paint has probably burnt off, door and switches will probably need replacement, the turntable plate, and additional parts "turntable motor" and other major parts are suspect, replacing the microwave oven in my view is the safest alternative.
Mar 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
There is a plastic oval piece that fits between the inside of dryer door and outer drum. This piece broke apart. Is this the cause of the noise when dryer is on? Close can easily get caught between frame...
Most frigidaire dryers have front felt seals with nylon slides on top that the front of the drum rides on. Without M# can't be sure if yours is like this.
Dec 28, 2010 | Frigidaire Electric Dryer
Leaving spots on clothing
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Dec 24, 2010 | Kenmore Dryers
Plastic padle on inside of drum broken
Yes the paddles can be replaced. www.bellparts.com type in your model # and locate the paddles.
I hope this helps you.
Vic
Jul 12, 2009 | Washing Machines
When the drum gros around, it sounds as if a coin
Hi The noise you are hearing is coming from the baffles inside the drum. These are attatched to the drum with screws from the outside of the drum. Something as gotten inside these baffles and causing the moise.
Remove the front ot top panel (Depending on what model) and take the screws out so the baffle releases.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | Dryers
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Jun 07, 2009 | Dryers
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Kyocera 1810 drum replacement
First, what kind of technical background do you have? Also when replacing the drum you should replace the drum blade. Most of the drum/blade kits do not come with padding powder anymore so you will need the padding powder also -- if you do not use the padding powder you will get drum blade jitter and trash the brand new drum!!!!
TO replace the drum you will need to remove the toner cart., 1-2 covers, the dev. unit (developer) and then the drum unit. You will then have to take the drum unit apart to remove the old drum and blade. *****NOTE***** DO NOT TOUCH THE DRUM SURFACE OR THE MYLAR (RUBBER PART) OF THE BLADE WITH YOUR SKIN!!!!!! The oil from your skin will damage the drum and could damage the blade, again -- then they would be trashed.
I would spend the money to have a trainer tech. come out and replace/ rebuild your photo conductive unit for you. It would be money well spent.
Oct 29, 2008 | Kyocera KM-1510 Copier
Toner Error
It's possible that the toner has not been reset due to the fact that you changed the drum at the same time. There is a cover on the left hand side of the toner covering some gears. Remove this (one screw) and wind the toner reset gear (white one by memory) back and refit the cover and put the toner back in the machine. It may take you a few to get it in the right spot but that will reset your toner count and get rid of the error.
Jan 24, 2008 | Brother MFC-8460N All-In-One Printer
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Kenmore 63942 Dryer Logo
152 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
