Question about Vacuums
How do i take the old belt off of my dyson dc 14? cant seem to figure out how to get the roller separated from the machine because i cant get the old belt off.
  • 51 Answers
Go to: Dyson web site or
http://www.repairclinic.com/0100_24.asp
There should be 4 to six screws holding the bottom of the vac on to the vac frame. Take those out and you should see the belt and beable to remove it.
Posted on May 10, 2009
How do I fix the carpet brush on my dyson dc14 vacuum?
this is what is is broken it is the clutch Dyson clutch belt assembly for DC07 amp DC14 900252 04 473
most likley needs to be changed it is also a good idea to change the roller brush at this point also
Dyson Dc 07 14 33 Upright Models oem 904174 01
Jun 12, 2016 | Dyson DC14 Animal Bagless Upright Cyclonic...
Just purchased a reconditioned model. Makes a ton of noise and the bottom brush doesn't seem to turn like in my old Oreck. Does that indicate it needs a new belt?
Your Dyson does have a belt but its one that cant be replaced it is called a clutch assy. if your roller brush isnt spinning then it could be that you dont have the purple knob on the left hand side if your facing the vacuum to the carpet setting. if you do have it on the carpet setting and its still not spinning then your clutch need to be replaced.
dyson roller brushes donot rotate as fast as Oreck roller brushes. in fact they are rotate at about half the speed. so keep that in mind.
Apr 17, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC 14 Animal - The carpet brush does not turn. I cleaned thoroughly per the instructions but the brush does not turn. I tried moving the carpet/bare floors switch with the same results - carpet...
The brush will only spin when the machine is reclined. Not when the machine is stood upright.
If the brush doesn't turn when the machine is reclined, and the brush control set to "auto", you have a brush bar and/or belt problem.
Jan 18, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I reset the brush it won't turn on My DC 14 got jammed with carpet stings and now the brush will not turn on, how do I reset it.
you cant reset the roller on the dc14... you most likey have snapped the belt that runs the roller. DO you have the clutch version?
Oct 04, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
How do I replace the belt on the DC 17
Take out the (3) screws on the bottom of the brush roll cover and then you can remove the roller brush and change the belt. Here is the belt you need:
Dyson DC17 Belt
Jan 03, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson dc rollerbrush is very weak
Hi.
Can you follow the belt to where it goes around motor shaft or does it disapear through a hole in the casing ?
If it does disapear then your machine has A clutch.
The clutched Dyson machines have 2 belts One is motor to clutch the 2nd is clutch to brush roller agitator.
You will need to replace 0ne or both belts if you have the clutched machine.
Now if you can see the belt going around the motor shaft you havent got the clutched type just replace this belt regardles of if you think its ok.
If you need further help please look at this site has manuals.
http://dysondc07.topcities.com
Mar 28, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt
Hi.
Your Dyson will probably have A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left front side of machine looking from the front & rotates to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive.
If you still have no brush rotation after doing all this then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
There are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/index.htm
May 26, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Brush proplem
Hi Dave.
Ok you need to lift belt end of roller up, so that you get the roller straight then lower roller down so that both ends go in at same time down.
Use a large flat screwdriver to help lever roller up from belt end & watch your fingers (Ouch).
May 22, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
70 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
