Question about Toro Electric Trimmer
Model 51225 how do you rewind the string serial number 954552 electric toro 900 home duty trimmer weeder fully automatic line feed
SOURCE: I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Posted on Apr 25, 2010
  • 18 Answers
SOURCE: NEED TO REPLACE STRING ON TORO 15" ELECTRIC TRIMMER
http://216.213.143.2/ProAuthor/ManProc.cfm?&sk=9C8C458D-4977-11DE-9261-00D0B789305D&&ProcID=9812&ManualID=301&ProductID=-1&Edit=No&Skill=1&Lang=-1
Posted on May 27, 2009
  • 163 Answers
SOURCE: problems opening the weeder to replace the string
may have left handed treads on it
Posted on Jul 26, 2009
  • 623 Answers
SOURCE: Toro& Electric String Trimmer: how do you take the bottom part off?...
Look for a couple small windows on the sides of the center knob that sticks out, push in on these, they are tabs that hold the center knob on, after that the string bobbin should slip right out.
Posted on May 19, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Posted on Aug 27, 2010
Toro 8 inch cut home duty trimmer how do you remove the spool
You have to hold in the two tabs at top of spool assembly
Aug 30, 2012 | Toro& Electric String Trimmer
I cannot get more line out of my toro 15" electric trimmer. It cannot be empty, it has only been used once. The cutting line will not extend out any more. Should it not?
Sometimes the line can become fused together.remove the spindle and manually pull the line. Replace and the tap and feed should work fine.
May 12, 2011 | Toro& Electric String Trimmer
My Toro 12" Trimmer (Weed eater) needs a new screw down cap to hold the spool in place. Home Depot no longer carries them. That's wheree I got the last two Weedeaters.Please give me instructions as to...
Your Toro electric trimmer parts are readily available through www.partstree.com . However, to avoid having to pay $10 in shipping for a $5 part, you should try to find your local Toro dealer. They probably have the part in stock. Go to www.toro.com and search on the dealer/distributor locator to find your closest dealer.
You will need to know the model number (5 digit) and serial number for your trimmer. These can be located on a small sticker on the trimmer.
Oct 14, 2010 | Toro& Electric String Trimmer
Cordless trimmer 7inch cut model 51556 serial
Go here....you can download the manual....It's free!
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
Jun 16, 2010 | Toro& Electric String Trimmer
I have a 13" Toro model 51358 trimmer and it constanly has no string showing. I have to remove the cap and pull more out through the feed hole. Why?
the bumper on the bottom is worn out or the sprin inside it is broken. You should be able to tap it on the ground and string come out.
Jun 03, 2010 | Toro Electric Trimmer
String is wound incorrectly
Hello. Just pushing it back does not fix it. Cut off the excess and then you should be ok again. J.
May 24, 2010 | Toro& Electric String Trimmer
After going through at least 3 string-type lawn trimmers, I have yet to find one that can actually feed the string. I have used Black & Decker, and most recently, Toro 8" cordless, with the same...
This can and is a frustrating problem. Some things that help are to be sure to use the right size of trimmer line. Be careful when rewinding the reel to not twist and cross the lines. I realize we should not have to give this much attention to it, but until somebody "builds a better mousetrap", we only have so much to work with.
May 15, 2010 | Toro& Electric String Trimmer
Want down to down load owners manual for Toro 7 inch trimmer model 51556
If you use this link:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Then type in your model and serial number, You can download your User's manual. Toro is pretty fussy about handing out manuals hence the model number AND serial number are required in their site.
Thanks for using FixYa,
Kelly
Apr 29, 2010 | Toro& Electric String Trimmer
It has come apart and I would like to refill the line on my toro heavy duty electric trimmer
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 23, 2009 | Toro Garden
Toro Electric Trimmer Logo
769 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
