Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Pilot lights, but heater does not ignite.
Lars LG125n-c (model #)
Having problems with heater , pilot stays on but heater will not kick in.
Could it be my thermolcouple?
Longbow
  • longbowgater May 11, 2009
    It's an above ground pool heater 125,000 btu's
    natural gas
Yes it could. what kind of heater is it?
Posted on May 10, 2009
Convert Laars lite model lg125n to LP gas
That involves changing out the complete burner tray including the igniter/pilot assembly, burners and the gas valve. It runs deep into the cost of a new heater, (well over $1000, not installed).
Nov 27, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
We have a Jandy Lite @ Model LG125N pool heater. The gas pilot turns and stays on but the burners won't ignite? Looking for firection on potential problem and how to fix. THX.
The reason it doesn't light is that the electrically operated gas valve is not coming on. It could be defective or the control circuit that tells it to come on is not doing that. If you have a meter and can connect the leads to the wires on the valve you should get 120VAC when the control circuit tells it to open. If you don't get this then the control circuit is not telling it to open. With the power off, check the resistance across the thermal safety device. It is located usually on the far left. It has two wires and they connect to a small axial leaded device. If it gets too hot it opens and prevents the heater from coming on. If the resistance value is very low, under 1 ohm, then it is OK. Other switches that could be open include the thermostat switch, the water flow switch, etc. Any one of these would prevent it from coming on. If you call the Jandy technical support number they might be able to help you diagnose the problem. I hope this helps.
Aug 13, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Pilot light lights but the main buner does not kick on
I'm having the same problem! Bought new thermacoupler and thermostat and it still won't stay lit.
Mar 30, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Laars model# LG125n-c having problems with heater , pilot stays on but heater will not kick in. Could it be my thermolcouple? or my pressure switch? Natural gas 125,000 btu's for above ground pool
could very well be thermocouple or fan switch if you have a meter that reads millivolts you can check thermocouple output or fan switch for continuity if you jump out fan switch be careful cause you can go boom if you are not familiar with this type of equipement you should call someone who is
May 11, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
372 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
