Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Honeywell time control st6300a
Hi
I have removed the front of my time control, however when I done this a number of the wires popped out as they weren't secured properly. Would anyone be able to help me out with a wiring diagram as I'm not 100% sure wher the 2 wires should go?
Cheers
Stu
    Problem Solver:
  • 19 Answers
A basic thermostat such as this will only have 3-5 wires that are used on it. First, shut off the power to your furnace, usually by a switch close to it, or with the breaker for it. Red will go to the R terminal, White to the W, Green to the G. Some techs will use blue for the Y terminal, or yellow if it's available, if blue or black is left over and you have a C terminal on your Thermostat, place it there. Hope this helps.
Posted on May 17, 2009
How do I replace a Honeywell ST6300A programmer
Peter there will be a couple of retaining screws on the bottom attaching it to a back plate. Then it should lift off and the new one goes onto it.
Nov 30, 2014 | Heating & Cooling
How does one wire a 24 volt White-Rogers evaporative cooler controller replacement for an ancient mercury switched Honeywell controller?
Red wire, R with a jumper to RH
White , W
Green, G
Yellow, Y
Make certain you understand thermostats come setup for gas, so pay attention to what your heat/cool unit is, that's very important, also make sure to shut off the power to your system before removing the thermostat.
Jul 08, 2014 | Honeywell Heating & Cooling
Honeywell st6300a
change the battery if it has a back up one
May 27, 2014 | Heating & Cooling
Correct signal does not seem to be sent from the controler to the boiler,either CH comes on or HW but not necessarily when they are supposed to. Boiler engineers have been out twice and both times advise...
we had one of these and found out the battery inside had failed. the battery is none replaceable. did try to replace it but it lost its memory and was only good as a switch. think when the battery fails it loses it memory and things start going wrong. so would say change it. now thinking on it should of changed the battery why having the old one on and taken the old one off after installing the new one.
Mar 03, 2014 | Honeywell Programmable Thermostat Heater
Yourhome honeywell com
To start, most tstats pull straight off of its base, or pull away from the bottom and lift from the top. Yours should be a touch screen and pulls straight out. Hopefully the installer secured the base well enough to the wall. At the tstat that has dehum. capability, see if it has a terminal marked D or H for dehum. If so, there is a wire connected. Now at the 1 you would like to replace, remove tstat from base, and check the number of wires you have available. If you don't have a "spare" wire for the new tstats' H(humidity) terminal, it won't work out because you'll need an extra wire. Also the existing tstat may have that option, but isn't configured for dehumidification. Might check that too. It is possible to add dehumidification to any and all zones depending on available wires. Also, at the geothermal, this "extra" wire needs to be connected.
Mar 10, 2017 | Heating & Cooling
How do you remove cover from honeywell ST699B
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 20, 2010 | Honeywell Programmable Thermostat Heater
Two furnaces one humidistat help on wiring
Honeywell tech support is awesome here in Minneapolis, I think you need seperate humidistats but check with HW, number is in owners manual.
Nov 21, 2009 | Honeywell Power Humidifier: Furnace...
Hi! Need help in removing the front panels of 2009 nissan altima so I can install a radio. the car is basic, have all wiring and speakers, but no radio, i have the radio, harness and mounting kit, but I'm...
well to start you will nee an install mounting kit metra number 99-7423,
a wire harness 70-7552
and an antenna adaptor number 40-NI12
Now to remove the stereo you will need to pop off the trim ***. just below the heater control switches. the the vents above the radio. remove four phillips screws and then pull stereo/ heater assembly from dash.
Aug 27, 2009 | Car Audio & Video
Honeywell 7500
Yes you have the control wires swapped around on the thermostat. take front off and remove it from the wall. turn unit off with the breaker for safety. although the thermostat will not shock you. write down how the wires go on just in case you pull some lose by mishap, they will be a yellow and a blue or brown you should only have two of the three swap them and check.
Aug 09, 2009 | Honeywell Programmable Thermostat Heater
Honeywell HZ517 Baseboard Heater
You can try to disassemble the heater and look for something wrong like a loose wire: in order to do so: Unplug the heater and let it cool completely before disassembling it. Remove the rear grille and the control knobs. Remove the front grille by unscrewing the fasteners on the back of the housing. Remove the front grille by lifting the control housing and pulling the front grille toward you. The motor, fan, and heating element are now accessible for testing and repair. Remove the thermostat from the control housing and disconnect the wires. Remove the heat control's mounting screws and clips to access and disconnect wires. Good luck
Nov 28, 2005 | Honeywell HZ517 Baseboard Heater
Heating & Cooling Logo
258 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
