Kenmore Elite fills with water, then stops. Only continues if I manually move knob to a different spot and it happens to go back on. Never the same spot though! Why would it get stuck? Is motor going out or water pump, or it just needs...what?
  • steve
    steve May 11, 2010
    Model number?
  • 68 Answers
Doesn't sound like anything is wrong with the pump because all that does is drain the water from the tub, my guess is you have a timer issue which is keeping it from going to the nexts cycle, or it could be you lid latch switch is going bad because if its not working properly it would keep the washer from going through its spin cycle to drain the water.
Posted on May 10, 2009
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Kenmore 80 Series Overflow
We've now had this happen three times and the exact same thing caused it all three times.
If the water level selector knob hasn't "clicked" into one of the given load levels on the control panel(i.e. the knob is in between levels) it will continue to fill until you discover water everywhere and turn the knob until it "clicks" into a level.
As far as I know, it has nothing to do with loose hoses or bad switches, it's bad design. There seems to be no safety mechanism to turn off the water if you over- or under-shoot the desired water level.
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Kenmore Elite Washer
seems the timer knob is old and need of replacement normally happens due to age as the timer switches inside the timer knob become old and sticky mostly unable to move so the timer isnt able to do much of its job
Apr 17, 2017 | Kenmore Washing Machines
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
