Question about Sony Computers & Internet
Problesm with you tube to play
''you Tube'' comes up ok but stops too often and doesn't allow me ho hear a song
  • 4 Answers
Check you codecs, if not, its a speed problem (too much buffering)
run netsh winsock reset catalog from the command prompt
this should sort your problem
Posted on May 27, 2009
Lenovo thinkpad 520 needs a program installation or reboot of something that will allow me to play and hear videos ie you tube
See this page on requirements
System requirements
Adobe Flash Player and Internet Explorer will work on Windows 7.
Links on this page to download the software required (free).
Mar 03, 2015 | Lenovo ThinkPad Computers & Internet
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Feb 16, 2013 | Kohler Toilet - One Piece with Ingenium...
How can i downlond rap music and video
Go to google.com then type in mp3 rocketvideos and click on mp3rocket.com and click on download and wait till it installs then open it up on your desktop and you can click on one of 4 categories music, video, game and that and type your song you want to download or hear and if u want to download it click on the word DOWNLOAD and select what folder on your computer u want it saved into I put mine in MY DOCUMENTS then I double clicked MY VIDEOS then click on OK wait for it to finished then go and play it in your folder. You can play a preview of the song by clicking on the PLAY button that looks like a arrow pointing right in a blue circle. These songs, videos, games are all free and come through you tube.
Dec 21, 2011 | Computers & Internet
Have a fluidmaster 400A. After the tank refills and turns off, some water continues to trickle through the hose into the overflow tube causing a trickle into the tank. If I pull the hose off the 400A, I...
make sure you have the overflow tube, ( the small black one) attached to the clip so it doesn't go too far down the fill tube,, otherwise it causes a siphon and you will hear a trickle, you can also turn off the water, and grab the top of the valve, turn it 1/8 of a turn, and check for any debris inside that cavity, clean and reassemble
Jul 10, 2011 | Home
Fluidmaster model 200a, water keep on filling inside the tank even when it is full.
ok,, if you can lift the arm and it shuts off its just aligned wrong, shut off the water, reach down to the lower half of the fill tube,, you will see a little slide clamp, that slides off, and you can adjust the unit up or down to set the amount of water the tank allows to fill and turn off , also, if the over flow ( the small black tube) that goes down the tube that holds the flapper ball, is too far down inside of that tube, it will create a siphon so make sure thats attached to the metal clip that comes with the unit. If the water doesn't shut off when you lift the arm on the float bar,, you can turn the top of the unit 1/8 of a turn, and remove the top, check for any debris inside of that , you can invert a cup and hold it over the top long enough to shoot a short blast of water to clear the feed out. reassemble, and turn the water back on,, you may have to readjust the slide tube to the desired water height
Jul 08, 2011 | Plumbing
My Oasis washer flooded the basement during a wash cycle? How do I fix this?
If the machine doesn't stop filling, it can be one of 2 problems. 1. the inlet valve has jammed open - water will continue to come thro when machine is switched off. 2. the pressure switch has failed. This is located at the top of the machine under the top cover and has a tube about 1/4 inch diameter attached to it, leading down to the drum. As water enters the drum, pressure builds up in this tube & operates the pressure switch turning off the inlet valve. Either the pressure switch is faulty or, more likely, the tube has a hole(maybe tiny) in it and is not allowing the pressure to build up. To test the switch, pull off the tube at the switch. Connect another similar piece of tubing to the switch about a foot long. Switch the machine to start filling. Blow down your new tube to the switch. The pressure you create should switch off the inlet valve while you keep the pressure up. If the water stops coming in, the switch is ok - suspect the tube. If the machine continues to fill, the switch is faulty.
Jun 23, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My computer suddenly stopped playing the music clips on you tube. A few will play but most will not. What happened?
since Youtube music is free and most of the songs etc. are uploaded as marketing mode. So it won' play the full list very few will play properly . So try any pay site
Feb 23, 2010 | YouTube Computers & Internet
Water will not stop filling up the washer after the rinse cycle and it overflows into the floor.
Does it shut off the water if you turn off the washer? if so then it may be the water level pressure switch. I've only seen one go bad in all my years but it can happen. There is a tube that runs from the side of the drum to a cylindral style switch located behind the control panel. as the water rises the pressure does as well. thats how it senses the level. Either the tube is being blocked by foreign matter or the tube may have a hole in it or it may have come off. Check this first. if everything appears ok then you may have a bad pressure switch. I normally hook a (CLEAN) tube to it and blow into it. You should hear a click then the solinoid shits off the water. That's How I check 'em. Lastly, if the water does not shut off when you turn off the washer, foreign materal may have gotten in the water inlet valve and is not allowing the solinoid to close to stop the waterflow. If this is the case, try disconnecting the hoses and cleaning the inlet valve. In most cases it should be replaced.
Oct 15, 2009 | Kenmore 22422 Top Load Washer
Leaking fridge
The U shaped copper tube is most likely the drain tube where the water frost defrost exits and drains into a drain pan to be evaporated. Even thing is fine, do not shut it down nor call for service. If you hear it again wait twenty minutes and it should stop. Then check it and I'm sure you will find it is O.K.
Have a nice day.
Sep 16, 2008 | Refrigerators
Computers & Internet Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
