Question about Whirlpool LEB6300 Electric Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
  • Whirlpool Master
  • 3,361 Answers
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
Posted on May 10, 2009
I have a Kenmore Elite Dryer that is configured a little differently so I thought I would share the solution (only slightly different from the above. My dryer does not have the lint filter on top, it is at the bottom of the opening in the front (When the door is open)
1. Unplug the dryer.
2. Remove the 4 screws behind the control panel. Removing these will allow you to pop up the top.
3. Pull the lid forward and lift up to open. The controls are connected via wiring harness in the left rear so you cannot totally remove it, just tilt it up. I braced mine open with a small wooden stick so I could access the drum.
4. Rotate the drum until a tumble vane (paddle) is at the top.
5. There are 3 screws for each vane. Tighten the screws going through the drum.
You might want to remove them and clean them out before tightening them. I found lint and some lose change that was banging around inside the vane.
6. Repeat this for the other 2 vanes.
7. Re-assemble the dryer.
Posted on May 05, 2010
Got a Kenmore Elite dryer. Some form of fabric/felt gasket has come off from the gap between the spinning basket and the dryer body. Gasket seems usuable.
That is called a drum seal and it has worn out. you can buy a new 1 at a reasonable cost and it comes with the glue to hold it in place. Not a bad job to replace but you will have to stretch it a little bit to make it fit. I suggest get it ready so it will fit on before using the glue being the glue sets up quick. (I am a 14 year appliance tech)
Jan 02, 2016 | Kenmore Washing Machines
I just bought a used kenmore elite model # 60994990 after plugging in an testing 120v is good but the dryer itself wont start when i push the start button
open the door and check the door switch when moving it the paddle on the switch could have broke,also did you hear it run before you moved it?
Sep 25, 2011 | Kenmore Dryers
Brown marks are appearing on clothes after drying. These are not burn marks but rather something that is coming from inside the dryer.
I have the same problem. I have wiped the dryer several time with soap and water. I only found that it might be the glue on the felt gasket??? Dunno...
Jun 07, 2010 | Kenmore Elite HE4 Electric Dryer
Error code F44 on sears kenmore elite oasis electric dryer.Doesn't seem to be cycling completely.
The F44 error code on this type of dryer indicates a blower motor control board failure. Since it happens only occasionally, then you could have a loose wiring connection or a partial obstruction in the blower housing. Complete details of the troubleshooting for this error code are included in this link of a previous answer: What does the fault code F44 indicate on my Kenmore Elite Oasis dryer?
I recommend that you unplug the dryer and check the wire harness connections if you are confident that you can safely access the internal dryer components. If you find a loose connection, then tightening it or plugging the harness securely into the connection will likely correct this problem.
May 08, 2010 | Kenmore Elite HE4 Electric Dryer
What does the code f70 on a kenmore elite dryer mean?
F70 is a "communications error" message and the first thing to check is loose wire connections.
If a loose connection is not found, the controller board will probably need to be replaced.
Please report back here what you find, OK?
Aug 05, 2009 | Kenmore Elite HE3 Steam 8676 Dryer
Brown marks on clothes from kenmore elite dryer
i used to be sears repairman ask him if there is a recall on your pacfic model .. betcha there is on the dryer drum tell him u want the whole drum replaced on dryer u know exsisting problem having on this pacfic dryer remember satisfaction gaurented or money back...
Jul 12, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer Blower fan is loose
in the back opf your dryer the drum runs on 2 black rubber wheels when they are worn out it will giveyou that kind of noise replace them they cost about 8.00 each there is two of them you van see one from the bottom right side in the back of the drum if you remove the front lower panel thanks from gilles
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Kemore Elite HE4 Dryer
Hi! juysu
Please check the power cord, by checking if there is 240V on the power terminals inside the back of the machine where the power cord is connected.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite
It should just mean "Power Failure". Restart your dryer. Does your house loose power a lot? Or just the dryer. Check your power to the dryer.
Nov 18, 2007 | Kenmore Elite HE4 Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
285 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
