Question about Garden
PTO QUIT SHUTTING DECK OFF WHEN GOING INTO REVERSE, THEN QUIT ENGAGEING REVERSE OR FORWARD
  • 86 Answers
What kind of lawnmower is it ? Craftman has a position on the switch which turns off the deck saftey switch that shuts off deck,also it has a switch on shifter wires could have come off or switch could be bad .
Posted on May 10, 2009
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Http://www.recrepairinfo.com/product_info.php/tecumseh-peerless-transaxle-920-series-repair-manual-p-6176
are you talking about driving forward? that doesnt sound quite right. there is a reverse safety switch and paddle that are meant to do that exact thing but in reverse. Mine has a key position back one from where you release after start. when you move key to that position, i can go in reverse with the deck still engaged.
Jul 14, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
When cutting with pto on and going into reverse and forward again the pto cuts off
That is a safety feature. When the blades are engaged and you go into reverse, they will shut off until you get out of reverse and turn the blades on again.
Jun 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do you disconnect the reverse safety switch on a cub cadet 2160... where is it located?
Jun 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
