Question about Toshiba Computers & Internet
My toshiba tecra does not shut down after viewing tv, it remains hang on when i make tv card switched off. what can i do to solve the problem?
    Problem Solver:
  • 14 Answers
Have you got the very latest drivers (software) for your TV card from Toshibas website / support section?
Its sometimes worth downloading the latest software available, then uninstalling the existing TV Card program - reboot and then re-install the new stuff
Hope that helps
Posted on Dec 03, 2013
SOURCE:
ronaldo_ross
  • 1056 Answers
SOURCE: My Toshiba Tecra A9 overheats and shuts down
Check to see if the cooling fan is working properly. You should hear it running if you put your ears close when the computer is on. If the fan is working and the cause of overheating is not the fan, then you may have a deffective battery, check to see that the battery can take up charge. If the battery is fine, then you may have a chip inside the computer that is overheating because of internal defect. This job would be best left for experts.
Posted on Aug 06, 2009
  • 942 Answers
SOURCE: My Toshiba laptop TECRA A9 shuts down on second
Hi..
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Hot spot, fan always runs? Many laptop brands and models have characteristic hot spots, like a particular corner of the keyboard or over the battery compartment. Before proceeding with the more invasive cleaning techniques that involve opening up the laptop (and potentially breaking something), spend some time searching the web for user feedback on your make and model. The bothersome hot spot on your laptop that none of your friends or colleagues have ever hear of may be a characteristic issue with your particular model and not worth a major panic.Similarly, if the fan always runs, or almost always runs, it may be a characteristic of the particular model that it simply gets hot in normal operation, or the fan control software might be poorly conceived. As long as the laptop isn’t overheating, I’d probably learn to live with a fan that seems to run too much if it’s typical for the model, and only get worried when I don’t hear it anymore.
Regards
PCmania
Posted on Aug 18, 2009
  • 12 Answers
SOURCE: My Tecra Toshiba will not turn on or off, even plugged in.
Hello,your ac adaptor is busted and needs replaced,you are describing a voltage fail warning light.
Usually worn out components and definately cheap from ebay to replace whole charger with new one.
Posted on Feb 17, 2011
SOURCE: toshiba Tecra M10-17H running Windows XP wont shut down, just hanging after a MS update.......
Hold the power button until it turns off, then reboot. Try doing a shutdown and see if the problem is solved.
Posted on May 15, 2012
SOURCE: toshiba Tecra M10 hanging when windows is shutting down after an update
Are you sure you are not too fast or impatient for it. Sometimes after doing updates it might take awhile to get past the Windows is shutting down...
Give it some time and see what happens. If after 15 minutes it is still there, press and hold the Power Button until it shuts off then Reboot. Try shutting down again and see if it hangs.
Toshiba Tecra M10-17H running Windows XP wont shut down, just hanging after a MS update.......
May 14, 2012 | Computers & Internet
Toshiba Tecra M10 hanging when windows is shutting down after an update
Tecra A10 won't boot up. Laptop was dropped when running and froze. Shut it down to reboot but doesn't work at all. When the power button is pressed, the HDD LED illuminates for just over a second and then...
I suggest try going to Local Computer Centers, Have them check what hardware's are having problem, most likely there are problem with LCD, Motherboard, HDD.
Apr 21, 2011 | Toshiba Tecra A10 Notebook
How to install internal bluetooth card in toshiba tecra M2
  • Hi, there are two areas to view; the first, go to and Type in the Search window Bluetooth, next if you have the "Toshiba Application and Installer software?" Type: toshiba, if the (TAI) software appear in the search, open and "Install" Bluetooth device. If the solution helped, "rating it is appreciated, thanks"
Mar 11, 2010 | Toshiba Tecra M2 Notebook
I have A Toshiba Tecra 10 Laptop that I have just tried to connect to a Toshiba 32" HD LCD TV. There is no RED color on the TV when the laptop is connected. What should be red is black. Everything else...
Sounds like a bad connection with the video cable. If not then with the mating connector on the laptop or the TV. Try to narrow it down to one of the three.
Feb 15, 2010 | Toshiba Televison & Video
I am having toshiba M305-S4819 laptop. Since 1 week, touch and launch buttons are not working properly. It remains on even when i shutdown the laptop.
if you are using vista then you have to tell it to shut down under the start button otherwise it stays in rediness mode. it is the only thing that i really dont like about vista
May 12, 2009 | Toshiba TECRA P5 T7100 1.8G VISTA / XP PRO...
When scrolling a page the graphics roll up like a slow moving blind
Hi Linda,
Have you solved your problem? I have exactly the same computer - and exactly the same problem ... I would be very grateful if you could tell me if and how you solved your problem!
Thanks,
Ellen
ellen(dot)pay(at)hotmail(dot)com
Apr 19, 2009 | Computers & Internet
Toshiba TECRA A8 won't turn on
if you plugin the charger and the light in the charger remains that is does not flicker but when you plug it to the laptop it flickers the you have a problem with your motherboard. easily solved with a solder iron and the know how. but if you a novice take it to a prof.
Apr 13, 2008 | Toshiba Tecra A7-S712 Notebook
Open Questions:
1 833 781-6786 TOSHIBA wireless Printer teCH SupPoRt pHoNe nUmBeR#@ PRINTER USA Sometimes, TOSHIBA Printer the best solution is also the easiest. If you're having trouble set up printer, driver installation, wait a few minutes, and then install toshiba printer divrer back in. This will often do the trick. Clear browser cache, cookies and history When you visit a website, temporary Internet files, cookies, and your browsing history are stored on your computer to record your return visit. Deleting these files Internet files, cookies, and browsing history can often fix the problem you're experiencing. The instructions to clear your cache, cookies, and footprints will differ depending on the browser you use. Please visit our help article Clear cookies, cache, history and footprints in your browser for instructions on how to clear your cookies, cache, history, and footprints on your particular browser. Reset web settings Resetting your web browser back to the default settings can help fix the problem. Please read our help article Reset browser security settings to default level to learn how to reset your browser security settings. DISCLAIMER: - We are an independent organization working as online third party technical support company for business and personal Error software, ERROR s and error support. We are not in partnership with any brand or any trademark term mentioned in the blog. We solely provide technical support to users of the brands mentioned in the blog.
Jul 15, 2019 | Toshiba Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
