Question about Compaq Presario 1200XL104 Notebook
I have a compaq 1200 laptop that won't turn on when i plug in the power supply the green light turns on but the computer won't turn on. I need a fix for it.
    Scholar:
  • 70 Answers
The first step I would take is to unplug both the AC adapter and battery from the laptop, then press and hold the power button down for about 15-20 seconds to flush any remaining power from the system. Then plug just the AC power in and try turning it on. If it turns on, then plug your battery back in, and you should be alright, unless your battery causes the problem again, in which case you'll have to run it without the battery (And don't bother looking into getting a replacement, this computer is far too old for that).
If it still doesn't turn on though, then what you may need to do is, make sure it's off, remove the power/battery again, and locate where the RAM modules are installed on the unit, and remove them, then plug it back into AC power only, and try turning the unit back on. Hopefully what this should do, is not only turn the unit on, but also get the computer to emit a series of POST error beeps. If it beeps, then it's more than likely one of your sticks of RAM that's failing (but again, due to the age of the computer you probably won't have much luck finding replacements), but if it still doesn't turn on after removing RAM, then, it's more than likely a failed motherboard in the unit.
I think the bottom line, for this laptop, is that it's probably time to retire it for good. This is quite an aged laptop (Shipped with Windows 98 SE, 32MB RAM...) so chances are pretty good that it's reached end-of-life. If you're concerned over retrieving the data from the laptop though, you're probably still in good shape to have it done. You can either have an authorized repair center do it for you, or, if you want to do it yourself, purchase a 2.5" IDE notebook hard drive enclosure. Which will basically turn your internal hard drive into an external USB one that you can plug into a new computer to retrieve your data.
Posted on May 10, 2009
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
Compaq Presario F700 Won't Turn On
Assuming the unit is plugged in, this could be an issue with the power supply, or an issue where the cord connects to the laptop. If the power connector on the back of the laptop is secure / doesn't feel loose or damaged, you may want to simply get a replacement power supply from a local electronics store. Be sure to take the make and model information of the laptop and the power supply with you to the store.
Jun 08, 2013 | Compaq Presario Notebook
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
Compaq Presario SR1123WM desktop won't turn on
Hello Kim.
When you press the power button, is there no life?
The PC may be set up for manual start instead of auto restart after power is restored.
Otherwise a surge may have blown the PSU.
Mine's not a Compaq but I'll research what the green light is.
Could be a modem....
Dec 04, 2017 | Computers & Internet
I have a HP/Compaq 6510b laptop computer and it will not turn on...I have the charger plugged in and the only thing happening is the green light periodically flashes...Is the battery bad?
IF the battery is bad the charge lndicator on the laptop will flash (But not periodically) it will be a constant on-off-on-off..... Best check would be to remove the battery completely and use the adapter/charger power supply only. If it still does not turn on then you either have a bad power jack connection or a more serious motherboard problem. Also is the green light flashing on the adapter/charger or is it the charge/battery indicator on the laptop?
Feb 17, 2011 | HP Original HP COMPAQ 6510b 6515b 6710b AC...
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
PC won't power on. Compaq SR5410F
IF you have another power supply you can use, try it and see if the computer will power up.
Oct 29, 2009 | HP Compaq Motherboard
Flashing power lights green and amber will not power up
Try removeing the battery form the laptop and using just AC porwer. if it still fails you may need to replace the motherboard. :(
Sep 14, 2009 | Compaq Armada M700 Notebook
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Compaq Presario 1200XL104 Notebook Logo
159 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
