Question about Refrigerators
Clicking sound coming from thermostat area - when it's clicking the temperature numbers are off - was clicking for short periods of time - now clicking for hours
  • 1 more comment
  • lhcap May 10, 2009
    Now, the ''open door'' alarm is going off -
    Model #PDS22SBSBRSS
    I think it's gone crazy - it's beeping with a tick tock sound now -
  • lhcap May 11, 2009
    I've called GE - they don't have an authorized service repairman for my area - gave me the number for A&E Factory Service - they don't have an authorized service guy for my area either - they gave me another 800 number - called that one - it was for Sears - I don't do Sear anymore - I can't wait a month for this to be repaired so I called a local repairman (35 miles away) he's coming Wednesday - I wonder is power surges could have caused this? We've had lots of storms lately.
    President:
  • 1,136 Answers
Hi, The clicking noise sound like a clock ticking? If so, it is probably you defrost timer. The defrost timer has a motor on it that sounds like a clock and has four wires that go to it..
This is what I would check first.
Vic
Posted on May 10, 2009
  • 1 more comment
  • Victor
    Victor May 10, 2009
    If you could get me a model#, I can investigate this problem further. It sounds like this is a newer model then what I first informed you about.
  • Victor
    Victor May 11, 2009
    Sounds like you might need to get a repairman so they can hear/see exactly what is happening. I am going to try and get some information on this tomorrow. If everything is staying cold, give me 1 day to get this info.
  • Victor
    Victor May 11, 2009
    Hi, It is very possible. I asked around tosay and that is the answers I got...... most probable.
    Good luck and I am sorry I could not give a deffinent answer.
Freezer temp cycles above freezing
If you have a frost free refrigerator then temp jumps as you discribe are somewhat normal during a defrost cycle. However it sound like your defrost temp may be getting too high. There is a limit thermostat on the freezer coils that keep the defrost temp from getting too high. The part is called a (defrost termination thermostat) and is a round disk about 1 to 1.5 inch in diameter clipped to the top of the freezer coils with 2 wires coming out of it. When cold, it allows power to the defrost heaters. At around 35/40 degrees it opens and shuts off power to the heater. 35/40 degrees sounds high for a freezer temp but that is behind the wall and only for a short time. Yours may be staying on too long or out of temp calibration needing replaced.
Mar 20, 2015 | Refrigerators
I have a Honeywell programmable thermostat and I have central heat and air system. When I set the heat to a temperature above the inside temperature, the heater turns on for a short period of time and then...
I would say that the problem is in the furnace, not the thermostat. The Thermocouple or other temp sensor needs replacing, the sensor that tells the furnace that it is heating. It just keeps turning off and trying again in 3 minutes cycles.
Jan 01, 2015 | Heating & Cooling
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
I installed a new radiator and thermostat in my '95 Buick Riviera and now the cooling fans are not coming on when the car warms up.What's the reason?
the cooling fans only come on when the engine gets to a certain temperature,they are not on all the time when driving above 40 MPH but will come on in stop & go traffic or when stopped at traffic lights after a short period......hope this helps....cheers
Jun 12, 2011 | 1995 Buick Riviera
I have set the times for the heating to come on and put it to auto but it doesnt seem to come on at the times i've set it at??
If the Procom Model number you referenced is correct, this heater does not have a automatic timing feature to turn the heater On and Off. However, it does have a built-in thermostat control, that turns the heater's burner on, once the room/area drops below the temperature/comfort level you have set it for.
Conversely, it turns the burner Off once it reaches and holds the temperature/comfort level for 5 minutes or more, it turns the burner OFF, again. Keep in mind, because this is a built-in thermostat, it's reading the air temperature closest to the heater.
If the thermostat feature is what you're having a problem with, it may be that the sensor bulb has failed (assuming it's not turning ON & OFF automatically). However, this is a fairly rare failure. Unless, the heater is very old or hasn't been cleaned and serviced annually.
Another situation would be that the Control Knob has been left in the PILOT position, rather then the ON position. If that is the case, the heater will not turn ON, period.
Right now, your Owners Manual is your best source of information on the correct operation of the heater, as well as it's Trouble Shooting Guide.
If you have misplaced the Owners Manual, here's a printable link to it. Just locate the Model Number of your heater, ML300TB and click on the icon to the left of it.
http://www.usaprocom.com/manuals.php
Hope this helps you solve your problem.
Mar 03, 2011 | Procom ML300TBA Heater
I just got a new Honeywell Utility Pro Thermostat. The digital temperature gauge seems very sensitive which results in the unit turning the furnace on and off for very short periods; much shorter than my...
Sounds like you also have a high efficiency furnace like mine.
Here is a procedure to slow down the number of cycles you are experiencing.
1. press System
2. press and hold buttons 3 and 5 on the bottom of the screen. (there should be 7 buttons displayed)
3. set code to 240
4. change setting to 3 for 3 cycles per hour. (your thermostat probably shows a higher number, probably 5? That is why your unit is cycling so often).
Jan 20, 2011 | Honeywell Electronic Programmable...
The water temperature guage on my 1993 Honda Accord stays on "cold" most of the time and the idle is high. It will go to normal for a short period and the idle will drop. Is this a sensor issue...
could be both at about 20 bucks apiece i would do both. would start with the thermostat you cause you can check it in a pan of water. but it prob stuck open from the sounds of it. protect your environment collect antifreeze in clean container re use
Dec 26, 2010 | 1993 Honda Accord
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Warming up problem
This has nothing to do with the element. This oven should only be serviced by a qualified technician. If you were one, you would already know the solution. You need to go into diagnostic mode to determine if it is the solid state relay or the cc thermocouple. After resetting the hi-limit more than once, it will also need to be replaced.
Aug 24, 2007 | TurboChef TORNADO Electric Oven
Refrigerators Logo
322 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
