Question about GPS
I have a Shipmate RS 5900 GPS Plotter
This is not captation the Satelites the anthenna is in a good condition
and the cable too
I need a solution thanks very much
4 Suggested Answers
SOURCE: User Manual of GPS Shipmate RS 5700
I have scanned the german manual of my RS 5700. If I can help you with that, give me a short answer to ernst.fischer@volkswagen.de
Posted on Oct 31, 2007
SOURCE: Garmin gps 72 not aquiring satelites
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Posted on Mar 24, 2009
sharcnet
  • 2130 Answers
SOURCE: GPS Firmware Upgrade Popup
Easy problem to repair. Please see this link for repair assistance.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Jun 01, 2010
Start a garmin 298 plotter
Anon, This is what I could find on the net, regarding your Garmin 298. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.gpscentral.ca/manuals/292-298.pdf
https://support.garmin.com/support/manuals/manuals.htm?partNo=010-00507-00&language=en&country=US
http://www.ybw.com/forums/archive/index.php/t-263039.html
Jun 27, 2016 | Garmin GPS
I have a ifinder hunt GPS, it will not locate any satellites, it then prompts me to stop searching or continue to search for satellites. I have been trying this device over the last 10 months, mostly on...
With a normal GPS device, when you first switch it on, it needs some time to locate enough satelites. Most of the time it needs at least 5 satelites. Some time should be like minutes and not hours. After the GPS device fond enough satelites, it knows where it is and can when it is switched on again work faster. When you try to let the GPS search for satelites indoors, or without a free view to the sky, it is possible the receiver never can find satelites at all.
I don't know if any test of the Lowrance iFINDER Hunt GPS was placed on the net, but that is where you can check how long it should take for the GPS to find enough satelites.
Oct 30, 2013 | Lowrance iFINDER Hunt GPS Receiver
Hi, my Garmin 3010c is 40m off true position. I hav another plotter (not Garmin) an it't on the spot. It7s not the problem with poor signal. It has signal form 6 or more satelites but it is allways...
There are too many variables that will affect the GPS to determine if the Garmin is off or the other plotter.
The only way to verify the GPS is through controlled simulation or using waypoint averaging and survey benchmarks to confirm the location.
Aug 19, 2011 | Garmin GPSMAP 3010C GPS Receiver
My garmin nuvi 255w was bought in april 2009, now it often lost satelites while i'm driving, some times it lost satelites for more than half an hour so cannot be functioned properly; more so, it often...
You can update the software at no charge from Garmin. Get a mini USB cable, connect the Nuvi to your PC, go to Garmin.com.
The software updates are free, maps cost!
Apr 04, 2010 | Garmin nuvi 255W GPS Receiver
Two year old tom tom xl can take up to 15mins to get a signal any advice
The TomTom device needs to tune in on three or more GPS satelites to find your position. On start, it scans the hemisphere for any satelites and ten minutes and more are not uncommon to establish fixes on them.
The solution is a data package you can download from TomTom servers via the Home software, "QuickGPSFix". It holds precomputed satelite positions for the next few days which speeds up locking to satelites to a few seconds from minutes. However, you need to update the package roughly once a week or the initial delay will pop up again.
Feb 03, 2010 | Tomtom One XL GPS Receiver
It does not aquire satelites, a new aerial has been fitted and everything else seems ok.
Check voltage at the plotter antenna outlet. It should be at least 5 Volts .if not you have a blown internal fuse
Jan 03, 2010 | Standard Horizon CP-150 WAAS GPS Receiver
I bought a C80 Raymarine Plotter this has a NMEA pigtail with Brown, Screen, Yellow, Green And White wires I haave also bought a RS 125 Receiver this has a pigtail lead with Red , Green, Yellow, Brown and...
If you have a Raymarine pilot it makes sence to wire it all up to Seatalk. Wire as follows Red to red , silver to silver, yellow to yellow, brown(on rs125) to silver on seatalk buss Green (on rs125) to red on seatalk buss.The above is for the conection between RS125 and C80.
To hook the pilot to system you just need to hook the seatalk lines (red, yellow,silver) from the pilot to the conection with the RS125 and the seatalk cable to the C80.(Color for color).The sea talk connection for your pilot can be picked up from you course computer they are labeld and colored on the unit.
If you are not running a course computer as in the case with the older wheel and tiller pilots you will need to take a sea talk cable and cut it. Once it is cut you will see the red yellow and silver wires and you can tap into there . Remember to connect the cable back together were you cut it. Hope this helps
Dec 15, 2008 | Raymarine C80 GPS Receiver
Nov 09, 2008 | Garmin GPS 72 GPS Receiver
My institute has GPS Shipmate RS 5700. Unfortunately, the user's manual for the same is not available. Can you please send us the same? If yes, please send me the softcopy at sozdemir@kirancom.trOR serkanrealdemir@yahoo.com If you don't mind, send the same at all.
Thanking you in anticipation.
With best regards,
Oct 12, 2007 | GPS
GPS Logo
1,110 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
