Question about Acer Aspire 5050-3242 Notebook
Need to restore to factory default but my lappy gives me a blank black screen with a blinking underscore on the top left of the screen.
I want to restore my acer laptop to factory default settings but i have 2 problems. 1st, the acer recovery system doesnt come with a cd. Because the recovery system is on the dektop itself. 2nd, my lappy when on, gives me a blank black screen with a blinking underscore on the top left of the screen. Please help.
    Scholar:
  • 70 Answers
There might be one step you could try to restore the system to factory specifications. When you turn the laptop on, and you see the Acer splash screen, press the Alt-F10 keys together at the same time, and this should hopefully bring the Acer eRecovery system up, provided that your computer has the built-in recovery partition. If it asks for a password, try using the default of "000000". If that doesn't work, then a password has been entered into the system, and there is no way to reset it, however there is a way to find out what the password is, however it does require the use of the Ubuntu Operating System (which is free to download, here)
Posted on May 10, 2009
  • Lawrence Cendana Nov 05, 2010
    if ever it doesn't work, how will I figure out the password with the use of Ubuntu. I know how to use this OS by making it portable to a usb/(or in other external drives), I can also browse files within it. Just the steps on how to figure this password.
    (My brother have the same problem but it is some kind of worse because everytime it happens, after fixing by reformatting and/or backup, after a meantime about weeks, problem exists all over again.)
    Pls help.
Black screen when switched on
Okay, does that laptop post to bios first? Example: You see the logo of the company before it goes to a black screen.
Also, do you see a blinking underscore in the top left hand corner?
Dec 09, 2012 | Computers & Internet
Whenever I try to start my Toshiba Satellite Laptop the Toshiba logo comes on but then the screen goes blank and all there is is a blinking underscore in the upper corner of the screen; I already set
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Jul 15, 2012 | Toshiba Satellite Computers & Internet
Asus eee pc not booting
Try to go to BIOS and run a HDD test.
To Go to BIOS turn on the NoteBook and Keep Pressing F2 and you will enter the BIOS set up.
Search for Hard Drive Test Option from the Menus
If the Test Passes then you need to Reload the Windows OS or if the Test Fails you need to get a New HDD
Jul 14, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Screen blank with blinking line left corner...when hit f2 bio utility comes up
Navigate with "tab" and arrow keys,theres just a few pages here save and exit or restore to factory defaults etc press "enter " to select or change option.get to know these pages and the boot sequence--good luck!
Davey Snake!
Oct 24, 2010 | ASUS Eee PC 1000H Laptop
Hello, I had recently tried to restore my hp laptop to factory settings, I had pressed F11 and followed the set instructions, ,but recovery manger said it cannot recover from recovery dvd so i tried...
go to the start menu and key on the program lower tab. The go to accessories. Click on command prompt which takes you to the DOS screen.
Now you will see a blinking cursor on the black screen which all you need to do is to type in chkdsk /f /r
This will repair any programs that were not running correctly. after it is done your computer may reboot itself. If not reboot it and see what it does, Itshould work fine unless deeper problems in the EXE BATCH FILE is present
Jun 20, 2010 | Computers & Internet
Blank screen blinking underscore Toshiba laptop after startup
if you can get into the BIOS-setup, verify if your hard drive is recognised as a bootable device and set as first boot device. if the disk is not recognised, you might want to verify if the P-ATA/S-ATA controllers are enabled. if this is all the case, but the problem remains, then your hard disk is probably broken.
Oct 05, 2009 | Computers & Internet
I have a ten year old compaq presario. i turned it on and a black screen came up with a white underscore at the top left corner. the underscore blinks repeatedly forever! i have looked inside my computer...
It sounds like the Hard disk has failed. You might be able to replace it if you can get one from a computer swap meet. but you are likely up for a new PC.
Jul 16, 2009 | Computers & Internet
Windows vista won't start
Open your system and fix any cable inside the system, maybe gor a loss connection. i guess that hard drive not detected. so fix it. please tell me what happen next i will surely give you more solution in it.
do not rate me if this not solve the problem.
at last remove and clean the memory fit it exactly to the slot.
best regards,melnavz
Apr 09, 2008 | Gateway GT4022 PC Desktop
Blank screen nothing left
ok...do you have the install CD around? Slip that into the cd/dvd reader, and restart. The system should read that, and ask to reinstall your o/s. Hopefully, your data is still good on your hard drive.
Feb 16, 2008 | Acer TravelMate 290 Notebook
Acer Aspire 5050-3242 Notebook Logo
498 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
