Question about DeLonghi Microwave Ovens
Using the convection oven mode, the oven doesn't
I have a DeLonghi DMX65 combination microwave, convection and grill. Using the convection oven mode, the oven doesn't get hot and after a few minutes stops. The display reads ''E 2'' and the oven beeps repeatedly.I've had the unit for about 2 years and it was functioning perfectly until an hour ago.
    Brigadier General:
  • 8,619 Answers
Hi!
This error occurs due to these two reasons viz. oven too hot or door latch problem. Please check both these parts and replace oven temperature sensor or door/latch switch, if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
Do I keep the glass plate in the microwave when on convection oven mode
If it came with the oven a definite yes as it will be able to withstand the heat during the convection setting. If a ordinary plate is used it must be rated for use in ovens as it will become very hot on convection oven mode. So, if it can withstand use in a ordinary oven it will work just as good in a convection oven.
Mar 14, 2016 | Sanyo Microwave Oven with Convection and...
I hv got a ifb microwave oven 23sci with grill , i have tried baking cakes many time and every time it gets burnt. The sides get baked and the central zone is unbaked. MY method is , I take a glass utensil...
You should be using convection mode first of all. It's not clear from your post if you are. Also looks like you're oven is baking at higher temperature than it says. Try 170 degrees for 13-14 mins instead.
Feb 28, 2011 | KitchenAid KHMC107BT Convection/Microwave...
Microwave not working
Magnetron may have died or internal fuse may have blown.Its could be all sorts of things.
May be time to buy a new one!
DO NOT TAKE OFF THE COVER YOUR SELVES, AS THEY MAY BE ELETRIC CHARGE STILL PRESANT EVEN WITH THE PLUG DISSCONNECTED
Sep 18, 2009 | DeLonghi MW 535 Microwave Oven
GE #JE1590BC01 will convection & combination, but not microwave
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
Accessing some components for testing will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
The owner's manual will also tell you how long your magnetron warranty is - it's usually 5 to 9 years.
Jan 17, 2009 | GE JE1590 Convection / Microwave Oven
When in convection mode on DeLonghi combination microwave, it stops after being set and comes up with E
That would be an error message, and I would bet it has a bad thermistor or a problem in the damper mechanism or circuit.
You should be able to find help at the DeLonghi customer service site.
Nov 25, 2008 | DeLonghi Microwave Ovens
DeLonghi combined microwave/grill/oven.
Found this posted in GE instead of DeLonghi but the basics are the same.
You say it stopped working - you mean it runs but doesn't heat?
Nov 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Microwave NN-A770S getting hot on right side externally
If you described this to Panasonic very carefully, and they said it's normal, then I would say keep using it until such time that you get other symptoms. The inverter has some parts mounted on a large chunk of aluminum called a heat sink. It draws the heat out of the parts and the heat radiates and/or convects away. This keeps the circuit parts from overheating. As long as you have good air flow through the vents, it sounds okay.
Sep 13, 2007 | Microwave Ovens
Microwave Ovens Logo
85 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Lisa
Lisa
tfelton3
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
