Question about HP LaserJet 1320n Printer
HP Laser 2200 d
We have a HP Laser 2200 d that was bought in 2002.  When we print it looks like the text is repeated on the paper all the way down in a residual ink. It is much dimmer and shadowy and overall looks dirty.  I am not sure if I buy a new cartridge if this will be remedied or if this is somehow a bigger problem.  We have followed the cleaning technique from the user manual and have called tech support, but our printer is out of warranty and they suggest buying a new one.  Just wondering if anyone has any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Make a print and stop in the middle of the printing by openning the door, take out the cartridge is it doing it?
if yes 1- change the toner   2- if no then it is the fuser ( where it comes out HOT
You will have to weigh the cost of replacing these two items vs getting a new printer.
Posted on Oct 18, 2007
Can use a glossy paper?
If the glossy paper is rated for the printer you are using yes. Never use paper that is only rated for inkjet in a laser printer. Many special inkjet papers have coatings that will melt or break down due to the heat of a laser jet and may damage your printer.
Jan 14, 2015 | Office Equipment & Supplies
Tip
How to Differentiate Between Laser Printers & Inkjet Printers
You require a new printer but you do not know whether to buy an inkjet or a laser printer, as you are not aware of the differences between the two. Each user or organisation is faced with the dilemma while buying a new printer. Most customers operate under strict budgetary constraints and it is only normal to consider initial purchase costs and space limitations. However, it is prudent to take into consideration the long-term operating costs associated with the particular printer.<br /> The choice of printer will, largely, depend on your requirements. Inkjet printers are usually ideal for home users who have limited text and photo printing needs. Laser printers are better suited to larger office environments with high-volume and high-quality printing requirements.<br /> The differences between a laser and an inkjet printer are generally categorised into a few broad segments, namely, cost (initial and maintenance), speed, quality, space and networking facilities. It is also essential to understand the technology behind the manufacturing of the laser toners and ink cartridges as this is a major contributing factor towards the cost.<br /> <b>Difference in Technology & Networking Facilities between Inkjet and Laser Printers</b> -<br /> The technology used for inkjet cartridges is simpler and the parts are less expensive than the laser toners. The black inkjet cartridge has only black ink. The color inkjet printer contains two main ink cartridges, for black and other primary colors respectively. The primary colors are then divided into three compartments for cyan, magenta and yellow ink. The primary colors are consequently mixed to produce all other colors. The cartridge contains a reservoir which has compartments with metal plates and a number of tiny nozzles on the print head of the cartridge. The number of holes or nozzles depends on the resolution of the printer. It is usually 21 - 128 nozzles per color. The ink gets heated, when the current starts flowing through the metal plates, after the print command is given. The heat causes vapor bubbles to form inside the cartridge and make the ink swell up. The ink then flows out in droplets from the nozzles onto the paper in a few milliseconds. A vacuum is created (once the ink droplet flows out) which draws more ink into the nozzles ensuring a steady supply of droplets as required. This common technique is called Thermal Inkjet and the coinage of the name 'BubbleJets' by Canon has been due to the bubbling vapors.<br /> The Laser toners use a more elaborate and complex technology. A powder called Toner is used by laser printers, fax machines and photocopiers to print text and images on laser and photo paper. Initially carbon powder was used but now manufacturers use disposable cartridges which can sometimes be refilled. For the laser toners, individual carbon particles are mixed in a polymer which melt in heat. This binds to the fibers in the paper. The laser printers consist of the printer toner and the drum. The positively charged toner gets attracted to the negatively charged drum. The toner is transferred to the paper by the drum. The toner contains special wax that melts and dries in milliseconds. When the toner is transferred, the fuser applies heat and pressure to make a durable image. The fuser system is made up of the hot-roll and the back-up roller.<br /> The high-end laser printers generally come with networking facilities for you to connect to your computer network directly. This cuts down additional costs associated with networking, as is the case with ink printers. The ink printers cannot be linked to a network directly. Networking has to be via a computer, therefore more expensive.<br /> The laser printers are larger in size than the inkjet printers. The latter is, therefore, space saving and ideal for the home and small office users.<br /> <b>Difference of Quality & Color between Laser and Inkjet Printers</b> -<br /> Since Inkjet Printers spill out tiny droplets of ink to print, the resolution is lower than the laser printers. Laser Printers printer better quality text, as their resolution is higher. High resolution also helps the laser printers create precise fonts without fuzzy edges. However, the cost-effective inkjet printers are usually recommended for inexpensive color printing. These can print high quality text, large photo prints, graphics, banners and greeting cards at less than half the price of a color laser printer. Nevertheless, it should also be seen if the cost of ink and paper suits your maintenance budget. Laser printers are capable of producing good quality prints on all kinds of printing paper but the inkjet printers will require inkjet paper to produce good quality prints without any fuzzy edge brought about by 'bleeding'.<br /> <b>Difference in Speed between Ink and Laser Printers</b> -<br /> If laser printers lose out to their inkjet counterparts on account of price, they are way ahead when it comes to speed of printing. Users who need large volumes of printing also prefer the laser printers. Laser printers are more suited to general office use than the inkjets. The least expensive laser printer can print around 10 to 15 pages per minute. The inkjets are usually rated on the speed of draft or quick printing mode, which is suitable only for proofreading purposes. The HP Deskjet 5650, which is a fast color inkjet printer, prints at a speed of 21 ppm Black, 15 ppm Color in the draft mode. However, the speed drops considerably when high quality black text is printed and it also takes longer to print a letter-sized quality photo.
on Nov 10, 2010 | Office Equipment & Supplies
Tip
How to clean ink cartridges HP deskjet printers
You need the following items to clean the print cartridges:
• Distilled water (tap water can contain contaminants that
can damage the print cartridge)
• Cotton swabs or other soft, lint-free material that will not stick
to the print cartridge
Be careful not to get ink on your hands or clothing as you clean.
To prepare to clean
1. Open the HP Deskjet cover.
2. Wait until the print cartridge cradle moves to the
center of the HP Deskjet and is idle and quiet.
3. Remove the print cartridges and place them on a piece
of paper, with the copper strips facing up.
CAUTION: Do not leave the print cartridges outside the HP Deskjet for more than 30 minutes.
To manually clean print cartridge contacts
1. Lightly moisten a cotton swab with distilled water and
squeeze any excess water from the swab.
2. Gently wipe the print cartridge copper contacts with the cotton swab.
CAUTION: Do not touch the print cartridge ink nozzles. Touching the ink nozzles will result in clogs, ink failure, and bad electrical connections.
1 Ink nozzles (do not touch) 2 Copper contacts
3. Repeat this process until no ink residue or dust appears on the swab.
4. Insert the print cartridges in the HP Deskjet, and then close the cover.
on Mar 16, 2008 | HP DeskJet F380 All-In-One Printer
TROUBLE SHOOTING FOR HPDESKJET 940C
You can try the following steps....
Turn on the printer and lift the top cover. Wait for the print cartridges to move to the center of the printer. Tilt the cartridges forward and carefully lift them out of the printer.
Dip a cotton swab in warm water and clean the metal connectors on each print cartridge thoroughly to remove all paper dust and ink residue. Continue cleaning the cartridges with new swabs until the swab comes away clean.
Vacuum the interior of the printer with a small vacuum cleaner like the kind used to clean and service computers. Continue cleaning the printer until no more ink residue and paper dust are found in the interior.
Wipe the inside of the printer with a soft cloth to remove any remaining residue. Reinsert the print cartridges into the printer, making sure they are secured with a click, and close the lid.
Remove all paper from the paper tray and flip the tray down so you can clearly see the inside of the printer. Direct a flashlight into the printer interior and look for any torn pieces of paper.
Grasp any torn paper firmly with the tweezers and pull it straight out of the printer. Examine the printer interior again with the flashlight to ensure there is no more jammed paper.
***If you need any technical help on printer then you can reach at here
Mar 06, 2013 | HP DeskJet Office Equipment & Supplies
I have the Hp 2600n color laser jet and it when i print anything it just repeats all the way down the page like the ink is bleeding
When the printer is repeating text, ghosting, it's usually caused by the fuser. The best way to fix this problem is to replace the fuser in the printer. Depending on how much toner you have left and the price of a new fuser, it might be more cost effective to buy a new printer.
Feb 22, 2011 | HP Color LaserJet 2600n Printer
Printing is blobby rather than sharp
That my friend is your cartriges,i had the same problem.
Sep 28, 2009 | HP Photosmart D7360 All-In-One InkJet...
Light purple cast to black and white prints
Known issue. Use QTR to print bw prints. Works great on my Epson 2200.
http://www.quadtonerip.com/html/QTRoverview.html
Dec 06, 2008 | Epson Stylus 2200 InkJet Photo Printer
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
HP LaserJet 1320n Printer Logo
69 people viewed this question
Clive
Clive
