Question about Whirlpool LER5636P Electric Dryer
Dryer will not heat but will run. - Whirlpool LER5636P Electric Dryer
  • williams2269 May 10, 2009
    The reading is 9.6, what do I do now?
    The meter is reading 9.6, what do we do?
  • 68 Answers
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
Posted on May 10, 2009
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Dryer does not heat up checked all thermostats and replaced heating element still no luck
hum... I ve seen where the motor was only getting 120 and not 240 and with most dryers they use 2 speeds or modes on the windings , 1 direction for drying with heat and the other to run minus heat thus if u only get 120 volts u have enough to run the dryer but not enough to run the heat to that dryer?
Aug 22, 2014 | Whirlpool EED4400WQ 29" Electric Dryer...
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Dryer runs but no heat
lean the exhaust vent tubes thoroughly and try again to heat up
a sensor in your dryer will shut down the heat if lint build up is present
Jun 07, 2010 | Amana NDE2330AY Electric Dryer
My dryer runs, but doesn't heat up...
heatman101
May 19, 2010 | Whirlpool LER4634J Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 02, 2009 | Whirlpool Dryers
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
397 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
