Question about RCA 25414RE3 Corded Phone
Phone does not ring
When I am on line 1 (in use), and a call comes in on line 2 the phone does NOT ring. (I do hear the alerter tone.. annoying) but I want the phones to ring instead. I tried turning off the alerter signal but the phone STILL does not ring when on another line talking.  Help PLEASE
  • auntygram Nov 27, 2007
    We have the same problem although there are times that none of the lines ring even if no one is on another line. We have unplugged, tried to get help from RCA and Office Max many times with no luck and basically have given up and glance to make sure the lights are not flashing indicating an incoming phone.
    Problem Solver:
  • 10 Answers
Without taking another look at the manual, the last time I read it I remember this is a feature, not a problem. The phone, if it is in use on any line, will not ring audibly when a call come in on another line (but will beep - after the second ring, I think - so that only you can hear it).
The presumption is that you do not want your party on the other end to be distracted by hearing a phone ringing that's only three feet away from your handset, AND that there will be someone else in the next office to pick up the incoming call.
As far as none of the phones ringing for an incoming call, I had some small difficulties with phone mis-behavior because I was using 50-foot phone cords when 7-foot was long enough. That didn't make sense to me, but when I shortened the phone cords from phone to wall, almost all the little problems went away.
Make sure you haven't silenced the ringer on the other lines.
Posted on Jan 31, 2008
  • 65 Answers
Have you called the support line for assistance?dial 1.800.511.3180
Posted on Jan 29, 2008
Why my nokia C3 doesnt ring accordingly although i set the ring tone already?its only vibrate.i'm not using silent mode.
I can imagine it how annoying it would be to you to see your cell vibrating instead of playing your favorite ring tone. Most probably it could be because of incorrect Profile configuration. It is possible to make your phone vibrate in almost every profile so we will assume that it is the reason for your problem too. Do the following and check some parameters as described.
1. Go to Menu > Settings > Profiles
2. Select Profile and then Select General.
3. After selecting General you will be given 3 options (Activate, Personalize, Timed)
4. Select Personalize.
5. In the Incoming Call Alert field, select Ringing.
6. In the Ringing Tone field, select your favorite ring tone.
7. Scroll down, (push down button) the next field would be Ringing Volume. For now select the max.
8. Scroll down to the Vibrating Alert field and set it to Off.
9. Scroll further down thill the very last field where it says Alert For, select All Calls for this field.
10. Save your modifications.
11. Activate the profile and see if it works now.
Only and only If it doesn't work, it may be due to software corruption.
In that case reset your phone to the factory default settings by going to:
Menu > Settings > Press UP button.
Select Restore Factory Sett. give your Security Code (default = 12345) and viola.
(Make backup of your messages ad contacts before attempting this)
Jun 04, 2011 | Nokia C3 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
To increases volume
first of all u can increase volume during call by pressing right button (middle one). but i think ur phone is set to max and u dont hear much - in this case probably some "metal dust" sticks on your speakers membrane - open case clean speaker gently or replace with new one...
Feb 07, 2011 | Nokia 1600 Cellular Phone
My office phone have a problem when customer call always complain i dont pick the phone but the problem is i dont hear the ringing tone please help
You can find detailed information about your phone from the given link below.
Panasonic KX-T7730
Check the steps below for "Does not Ring" solution.
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
img%20right%20hand.gif The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
img%20right%20hand.gif You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | Panasonic KX-T7730 Corded Phone
I have a motorola RAZR and the speaker doesn't work can it be changed?
Yes it can, but you'll need pricision tools to open it.
FYI: Speaker is used so that you can hear the other person from the other line talking.
Buzzer is used to hear your cellphone ringing, alert tones, alert tone messages, even making some music.
So in short Speaker is different from the buzzer.
Nov 01, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 | Nokia 3100
Incoming messages alert tones
first of all open menu of your phone then tap on setup(the one with screw driver on it) icon to open it then select ring alert style and select your alert style you will see a bottun bellow displaying "EDIT" tap on it then a menu will apear with volume level, Ringtone line 1, Ringtone line 2, Massage tone....
you can edit all of them by taping on the folder type icon flashing in front of them......!!!!!
I think it will help you...if not then reply me at ik1788@gmail.com
Feb 02, 2009 | Motorola Mobility MING A1200
My landline rings only once after which it goes to fax tone. If you pick up in that ring or else you will hear the fax tone. Even the caller hears a fax tone. I DO NOT have a fax in my house or ever...
This sounds like a crossed line and yes it is ATTs falt! call them back...Is this an apt unit you live in? somone could tap into your line.Check outside hookup/
Dec 11, 2008 | First Alert PIR720R 360 Hands-Free Light...
It alerts me every hour with a stupid mesage alert tone
Hi, there is a simple answer to this, from the main screen go into "settings", into 2 "phone settings", into 1 "date and time" into 1 "time" scroll down (4 times) to Hour indication (just after daylight saving) and change to off, thats it, no more annoying tones going off every hour. Hope that this helps
Good Luck
Dec 01, 2008 | LG Secret ? KF750 Cellular Phone
CHANGING THE RINGTONE
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Press STORE
Press STORE
Mar 20, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
673 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
