Question about Samsung CLX 3160fn All-In-One Printer
Internal Error 923 with Sending or Receiving Fax
1) Receiving a Fax : After 6 Bells the handshaking beginns. After the Handshaking - when the real Fax-Data is coming - the MFP stop immediatly with "Internal Error Switch off / on and the errorcode 923.
It doesn't do anything until it is switched off and on again (and it brings a paper with status : fax lost because of power).
2) Sending a Fax: Dialing a number and press "Start". Bevor one can hear, that it takes the line, it stops with exakt the same Error as discribed above.
I've just got my CLX-3160FN and found the same problems. Could go around the sending error, but can't receive faxes yet, always error 923.
Sending: make sure you press the "On Hook Dial" button before entering the recipient's number. Stupid, very stupid, but it's how it works.
Posted on Nov 27, 2007
I WAS JUST TRYING TO START MY oki printer c5600 model when I receive an error massage "923 fatal error" just the time it was about to initialize.
could you help me with the cause and solution
Posted on Jan 10, 2008
It is a mistake in software. Caller Name must not have a Blank
Posted on Oct 24, 2007
  • 161 Answers
Most probably, you need your mainboard replaced. Any authorized service center will gladly do it under warranty (if under 1 year). Ask the to please replace the power supply board as well.
Posted on Oct 20, 2007
Cannon Fax Machine Super G3 Unable to send. Phone rings but does not send. No error message.
In order to send, the recieving machine and the sending machine need to handshake (agree on setting, etc.)
If, as your description says the phone is ringing, I presume your are the sender.....what you need to hear is the other machine pick up, and then fax screech noises..... Test by calling the receiving fax by regular phone, and you should hear a pickup and fax noises....if not, your machine would never send.
Mar 26, 2011 | Computers & Internet
Mistake number 421*
According to HP, this error code means that a handshaking (connection) error occurred at some point in the process from the sending fax machine. They suggest to try the fax at a different time when telephone line conditions have improved, or that in some cases the error can occur if the other fax machine is using a fax format incompatible with the HP fax.
Dec 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Incoming faxes not coming thru, fax says "line error". How do I fix it?
There is a problem in handling the signals, usually it happens in handshaking. There are some error in the protocols. You have to ask a technician (you did not specify the brand of your machine), chance is, signal levels can be adjusted to as well as the communication speed.
Nov 18, 2009 | Sharp UX 300 Plain Paper Thermal transfer...
Error 441 seems to take all pages but receiver get aapx. 1 paragraph & the rest is blurred - same incoming
This means that an error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing) or the line speed drops to an unacceptable level.
Solutions
Check that the phone cord is plugged in correctly and is not cut, creased or damaged.
Make sure that the phone connection terminal box is not damaged and that the cable connecting to it is not damaged.
Try the fax at a different time when telephone line conditions have improved.
Oct 08, 2009 | HP OfficeJet d145 InkJet Printer
Have a client with 2 locations and in both locations the m3035xs mfp devices are constantly having communication errors between themselves and other recipients. The problem is primarily sending not...
Your machines are probably timing out waiting for space on the network
Some software is hyper critical when it comes to handshaking and stalls if its criteria is not met
We now test machines to the C drive of a host computer proving that it will up and down load and then tell the network guys to sort out their comms problems
Harsh but effective
Jul 04, 2009 | HP LaserJet M3035xs MFP All-In-One Printer
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Can't send faxes
FO is DIGITAL. You fax needs an ANALOG line.
Trust me on this.
Jan 17, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Error message 421*
error 421:
A handshaking error has occurred at some point in the process from the fax that originated the fax.
* Try the fax at a different time when telephone line conditions have improved.
In some cases this error can occur if the other fax machine is using a fax format incompatible with the HP fax.
- you can try to set the FAX SPEED to SLOW
- ERROR CORRECTION MODE to OFF
you can locate this on ADVANCE FAX SET-UP...
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Dell 962 printer
Remote fax error means there is something wrong on the receiving end, not with your fax.
It could be that it can't negotiate the handshake with your machine (that static noise it makes when it first connects).
Or it's not set to a receive mode.
Have you tried just calling the remote fax with your phone to see if you can hear that it is in a recieve mode (you'll get the static) or that it's not going to an answering machine by mistake (a common problem)
Aug 01, 2008 | Dell 962 Photo All-In-One InkJet Printer
Samsung CLX 3160fn All-In-One Printer Logo
654 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
