Question about Boating
Need online repair manual for evinrude 50hp outboard
I need to replace the prop seal and was looking for a online repair manual for a 1993 50hp evinrude outboard.
How can I adjust the shifting linkage on my 50hp evinrude. I have the cable adjusted all the way out but it will not go into reverse
Posted on Apr 09, 2010
HI I have a 1989 50hp Evinrude 2stroke twin. It was not charging so i have just changed the stator and reg. I started it up and it ran for about 5-10 seconds then cut out and would not restart. On checking the HT spark has gone, i have tested the charge coil to the CD unit and it reads 525 ohms would this be correct. Thanks Allan
Posted on Jun 12, 2009
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Does a 1977 Evinrude 70 horsepower engine hav a charging system?
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
Apr 25, 2011 | Clymer EvinrudeJohnson Outboard Shop...
Need a downloadable owners manual for evenrude out board motor model # 55975c
Hello Santos.
Give this site a try.
http://the-manuals.com/johnson/evinrude-outboards-vro-70-manual/
Or if you do not find what you are looking for you can try several from this page.
http://www.google.ca/search?q=evinrude+manual+55975c&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
I hope you find what you are looking for.
KL
May 01, 2010 | Boating
I need to replace the prop seal on a 1987 50hp evinrude
you need to disassemble your gear case, remove the prop shaft, and then replace the seals. however, if you are careful, it is possible to hook them out with a screwdriver and reinstall them but you need to be carefull not to damage the prop shaft . if you do the new seals will leak. also be sure to put some sealer around the outside of the seals before installing them and a little bit of grease on the inside lips.
Nov 15, 2009 | Boating
Honda outboard engine 50hp nrepair manual
Here is a link to clymer manual. honda won't allow free manuals posted online. you will need to purchase. click here
Oct 25, 2009 | Boating
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
Boating Logo
4,216 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
