Question about Sharp 32SC26B 32" TV
Loss of single channel digital.
Have had digital locals for 4 years. Just lost 1 recently. signal reads 95 but only get no broadcast now. All other digital channels ok and all other tvs ok on that digital channel. 32SC26B Sharp
  • Michael Deeny Dec 02, 2011
    I have just encountered the same problem. Were you ever able to figure out an answer for you situation?
SOURCE: Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Posted on Sep 22, 2007
SOURCE: screen blacks out on HD channels
Saying that the problem is with your TV doesn't make any sense since your TV is fed from the cable box.  Your TV doesn't know one channel from the next.  If it had a problem it would effect all channels.  You may not have enough signal to the INPUT of your cable box due to a problem on the pole or at your house or both.  Insufficient signal can cause some digital channels to not get decoded properly by the cable box.  The lower channels will show noise symptoms such as what you describe but they won't crap out altogether like the digital ones.  Have a cable tech come out and measure the signals.
Do you have splitters in line with the cable anywhere?  If there's any way to beef up the amount of signal getting to the cable box try it.
Posted on Oct 21, 2007
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
rapanSF
  • 150 Answers
SOURCE: Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Posted on Dec 03, 2008
dragon_rag27
  • 89 Answers
SOURCE: Distorted sound, great picture on a Sharp Aquos 42" LCD
i belive that it is the brodcasts problem there is nothing wrong with your tv
Posted on Jan 09, 2009
Why if my antena is hooked to my dvd player is it not getting channels but my tv is if dvd player is turned off
The reason probably is because all broadcast TV is digital, and the em-55 tuner is set for analog channels. It cannot receive today's broadcasts "thru the air" because channel 2 for example is not broadcast, rather channel 2.1, 2.2, etc.
You can use the signal with a new TV, but when you turn ON the em-55, it inserts channel 3.
Most all TV here has what I call sidebands, and some have as many as 11, so the tv can be set for 3.1, or 3.2 or 3.3.
Even if you have a digital-to-analog device, the em-55 will not receive any .1, .2, .3, .4 and so on. I verified this recently reconnecting my old antenna to the converter then to several VCR's and DVD players.
Turn off the em-55, and the dot channels pass through the RF connectors..
Some DISH, cable direct TV receivers convert the signal to ch 3.
Sep 25, 2014 | Panasonic DMR-E55 DVD Recorder
What does D03-1 mean
The TV has several inputs, Video 1, Video 2, HDMI, etc. One of the inputs is Digital. TV stations switched from broadcasting analog signals years ago. You may remember having to buy a digital antenna, or possibly if using cable or satellite service never knew it happened. You can press the input button on your remote until you see D03-1 on the screen and then do a channel search. You may pick up some extra channels that are being locally broadcasted for free in your city.
May 21, 2011 | Sanyo DP46849 46 in. HDTV
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
I PURCHASED A MAGNAVOX TB110MW9 CONVERTER BOX FROM WALMART. I HOOKED IT UP. IT SCANNED THE CHANNELS BUT IT KEEP SAYING NO SIGNAL.
I have a Magnavox TB110MW9A converter box that has worked fine for the last 8 months. Now you turn it on, the light blinks 31 times, stays on and there's nothing on the screen! The remote does nothing. (yes, I put new batteries in)
Jan 25, 2009 | Televison & Video
How do I set my PT-44LCX65 up to receive broadcast HDTV signals.
You should use the auto-program function in the customer menu. It will prompt you to select which antenna input you wish to program and then ask if you are on cable or receiving signals via "air" or "broadcast" mode. Allow the TV to load all the channels. You may notice that the auto program mode may move along quickly during the addition of analog channels and that during the scanning of the digital channels that it may look like nothing is happening. Patience is a virtue here. Wait until it has completely scanned both analog and digital bands and you will recieve both versions of the station's signal. If, for example, you have a local channel 5, the digital version will be 5-1, and so on.
michtech
Dec 18, 2008 | Panasonic PT-44LCX65 Television
Recently installed two Philco TB100HH9 Converter boxes. Both worked well at first then both lost a major local TV station within days and cannot reprogram it into the box. Have two other TV's without a...
I just had a similar problem with this box - For the first month or two, I got the local NBC affiliate (KING-5 in Seattle) just fine on 5.1, then, after fiddling with my antenna setup, I lost it completely - NOTHING I could do would get it back. I tried a bunch of stuff - Multiple types of antenna, adding an antenna amp box, a handful of "homebrew" antennas - Nada. Yet all my other channels came in fine (although a couple were right on the edge - This box seems to need a "17" or higher on the signal strength - Some of my channels were reading in the 15-18 range, and suffering the "blockies" and sound dropout)
After hitting TVfool.com, found out that the KING digital signal is actually broadcasting on channel 48. Punched in 48.1, and there it was, clear as a bell, using nothing but a "wick" antenna (Basically, strip 4-1/4 inches of the outer braid off one end of a piece of co-ax cable, leaving the center wire alone, then plug the other end into the box) getting me a 23 signal strength. But a second or two later, the box is displaying "5.1" - Weirdness...
Reconnected a near top-of-the-line Winegard Yagi/Log-periodic antenna - VERY directional, and has some gain all by itself - and the signal jumped above 50.
Still couldn't "channel-up/channel-down" or punch in "5.1" to tune it, though - Channel 5.x was a "dead zone" as far as the box was concerned.
Re-did the "autoscan", and now, it's back to normal - I can channel-up/channel-down to it at 5.1, or I can punch it in as 5.1, or I can punch it in as 48.1, and it's all good.
So, try re-doing the auto-scan. Worked for me...
Dec 01, 2008 | Philips Televison & Video
Sony Qualia and Sony XBR 4 TV
wow. mostly all new set from the last few years have a dual tuners
NTSC and ATSC and that would depend if or which set will get the better signal. Also remember that off air is analog and the sets are now design for digital.
Feb 09, 2008 | Sony QUALIA 005 46 in. LCD Television
Sharp 32SC26B 32" TV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
