Question about Acer Aspire 5050-3242 Notebook
Turned power off on acer ts---can't turn back on
I turned the power off on my acer ts and it won't turn back on. My monitor will not turn on either. What do I need to do to get if fuxed. Could it be in the switch or something else. I need to get some reports off of it this week, Can you help me?
Thank you, Barbara Hall
  • barbhall1 May 10, 2009
    The computer I am referring to is not a laptop. It is a personal desktop computer. It does not have a battery in it to my knowledge, Everything connected to it works, the printer,etc. It is simply that the power will not turn back on. I have a router cinnected to it for my laptop and it is working just fine. The monitor and computer power switch will not turn on. I only6 use ny laptop in emergencies as I di not loike the keyboard.
    Thank You, Barbara
  • 6,784 Answers
HI, you will need to replace the power supply unit that is located on the rear side on the top left hand side of the CPU tower. your power cord plugs directly into the device that will need to be replaced.
You can find these power supply units at any local CPU hardware store or best buy or office depot.
Posted on May 11, 2009
  • 854 Answers
Try doing a static discharge. Unplug the machine, take out the battery, hold down the power button for 30-40 seconds then try powering up again as usual.
Posted on May 10, 2009
I accidentally turned off my Acer monitor when I moved it, which lever turns it back on?
It might be possible while moving back the monitor cable may be loosen or it may have come out. You need to make sure monitor power cable is attached correctly to the power connector.
Also make sure you press the power button on the monitor as well as on electrical power switch to turn it ON.
GuruAid.com
Mar 16, 2016 | Acer Computers & Internet
Monitor won't come on when power on
Try unplugging it and then plugging in again, and make sure the monitor is turned on.
Apr 20, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
Acer Model 2216W Monitor won't turn on
There are usually one or two capacitors that open in the power supply, and in some cases they bulge at the top making it easier to spot.
Apr 02, 2012 | Computers & Internet
My Acer V223W LCD Moniter, It all started a couple of weeks back, when it went into sleep mode the screen would turn off and the power will flash from stanby to on then off and repeats. I could fix this by...
It also doe the same if you use this monitor to your brother's PC? Just want to make sure since you will have to open up the monitor if the monitor is bad for sure.
It is more likely to have power supply problem due to unstable DC feeding the circuits because of bad DC filter caps as you can see to these ACER monitors here and also ALL other brands as well.
http://s807.photobucket.com/albums/yy352/budm/ACER/
You can learn about troubleshooting here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 07, 2011 | Acer V223W Monitor
Acer monitor won`t turn on
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 24, 2010 | Acer 22" X223w LCD Monitor
Acer 1916 monitor..Power button flashing but won't turn on
Look for bad caps in the power supply first, post back what you see inside so we can guide you furhter, see example of failed monitors due to bad caps, lamps: http://s807.photobucket.com/home/budm/allalbums
Feb 10, 2010 | Acer AL1916B 19" LCD Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
Monitor goes black and won't come back
Hi! Trish,
It's seems your Acer monitor backlight inverter are burnt out. Need to replaced a new inverter. Since is a company monitor asked your boss to get you a new one.;) Hehehe...
Oct 03, 2008 | Computers & Internet
Acer Aspire 5050-3242 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
