This morning my Miele CVA2660 showed message that capsule was stuck. Following directions in book, I removed the capsule (this had happened before and the procedure worked fine) but when I closed the door as directed, the message was still there, "remove capsule plate and switch off at the mains," so I carefully went through the procedure again, same results, again, same results. On the left side is the triangle with an exclamation point in it. Please help!!!!!!!!
having descaled the miele built in coffee machine cva 2660 error f74 came up and it will no longer...
(More)
having descaled the miele built in coffee machine cva 2660 error f74 came up and it will no longer foam the milk for coffee or hot chocolate. what could be the problem ?
