Question about Brother HL 5170DN Laser Printer
I am trying to set printer HL 5170DN so that by default paper is used from the bottom tray and the upper tray will be set for printing off label paper, at present all print jobs are going through the upper tray only.. please help before i bang my head off the table..
  • 1 more comment
  • Hitch2504 May 10, 2009
    Ah maybe the problem is just with the bottom tray then cause thugh I have paper inside the bottom tray and no paper on the second roller tray it comes back saying it is out of paper, i've tried reseating the paper in the bottom tray and pulling the tray out and back in again with no joy, is there anything software/setting wise that could cause this as there is nothing appears to be wrong physically with the printer from what i can see :S
  • Hitch2504 May 11, 2009
    Thanks Greg i managed to get it installed and working today thanks for your input it was very helpful :)
    Solution offered helped a great deal, many thanks I managed to keep a difficult woman happy by getting the printer working ok.. still wanted to tie the flex around her neck mind, but i exercised great control :) thanks again,
    Gaz
  • 1,959 Answers
When the printer box opens up for a printing, click on the Advanced tab, then click on Quck Print Setup. From here you can click on Paper Source. Auto Detect is probably selected. On Paper Source, scroll down until Tray 2 is selected. Remember to click on Apply to keep these settings on all future print jobs. When loft on Auto Detect, If there's no paper in the upper tray the printer will try to print from the other tray. Remember, when you do have a label printing, you will have to adjust the settings for that individual printing or it will try to print from the bottom tray. To do this just go back to Advanced and select the upper tray and don't click Apply, just click OK so only that job will print from Tray 1. I do hope this straightens out your issue.
Posted on May 11, 2009
    Genius:
  • 1,847 Answers
Remove paper from the upper tray, it will automatically pick paper from the bottom tray.
Secondly there is only one tray on your printer that is the bottom one, do remember if the printer find paper in the upper roller (tray) it will pick the paper from there.
Let me know if you any question.
Thanks
Kevin
Posted on May 10, 2009
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
PRINT LABELS
You will need to use the manual feed slot which is above the paper tray.
The manual feed is meant for labels and envelopes
Dec 02, 2009 | Brother HL-5240 Laser Printer
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Usually won't print from upper tray
These printer have a problem grabing the paper from the upper tray it might look like it was ready to print but they usally miss grabing the second sheet of paper from the upper tray.
Jun 27, 2009 | Brother HL 2140 Laser Printer
Extra paper being fed after print job
Try a test page from the control panel, if this works properly you probably have an issue with the software of the printer. Reload the printer as if it was a brand new machine.
Jun 03, 2009 | Brother HL-2070N Laser Printer
Want to print on legal size paper from Tray 1 (top) as default
print menu - config and verify paper is being sensed correctly. If paper size in tray is not set correctly printer will ask where to print from
Feb 12, 2009 | Lexmark T640 Laser Printer
HL-2030 printer won`t print labels with Word 2007
If it's the same as my Hl-5250DN, you have to use MP Tray mode. The MP (multi-purpose) tray is cleverly hidden on the front of my printer.
Feb 01, 2009 | Brother HL-2040 Laser Printer
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
May 11, 2008 | Brother HL 5250DN Laser Printer
Brother HL 5170DN Laser Printer Logo
74 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
