Question about HP Photosmart M22 Digital Camera
Multiple flash firing
When in flash mode, camera will rapidly fire flash two to three times in a row. it is set at any flash setting, not just on red eye.
thanks
    Scholar:
  • 57 Answers
I would double check all your settings - even though you say it is on any flash setting, it sounds like it is using the nighttime flash setting (which does 2-3 rapid fire flashes).
Just go through every setting in the camera, and make sure that everything is set how you really want it, INCLUDING the daytime/nighttime, etc.
On the CAPTURE menu, check your adaptive light setting and make sure that you don't have it tweaked in some way to make the camera think EVERY picture is a nighttime picture.
I'd also check your "EV COMPENSATION" and "WHITE BALANCE", making sure those are set to "auto".
Hope that will work for you - good luck!
Posted on Dec 23, 2007
Camera won't flash
This will need to be tested at shop, too many variables to tell.
Nov 17, 2012 | Kodak EasyShare M530 Digital Camera
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
I have a HP Photo Smart R707 with a fully charged new battery and the flash won't work. Keep getting charging flash. Any help on this?
The flash mode has to be set.
There are 5 flash modes:
  • auto - flash fires when needed
  • red-eye reduction - flash fires when needed, but there's a pre-flash to minimize red-eye
  • flash on - flash always fires
  • flash off - flash never fires
  • night - flash fires if necessary (and uses red-eye reduction) to illuminate foreground objects, but shutter stays open to record the background by ambient illumination
http://www.bobatkins.com/photography/digital/hp707.html
Aug 11, 2010 | HP Photosmart R707 Digital Camera
I have three new Metz 58 AF-1N's, and a Nikon
take a silver paper and put in front of the slave censer when you take the photo flash on camera as master should go on silver paper OR used slaveunit
Jun 30, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
The flash will not work on my Samsung S860 Digital Camera. It used to work and now it doesn't... I tried to go through the menu to fix it and it seems to say it is on? But, when you take a picture it does...
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Mar 08, 2009 | Samsung S860 Digital Camera
Too many flashes
its the red eye setting in your camera you need to read the manuel and find the menu setting to change it
Feb 26, 2009 | Nikon Speedlight SB-600 TTL Flash
Metz 45CL-4 not firing consistently... Hi, Have a problem with a Metz 45CL-4 flashgun. I may have damaged the circuit by rapid charging from an external NiMh pack whilst trying to form the main capacitor....
Hi Guys!
I have had the same problem on CT-1 s and CT-5s.
In both cases the flash cable (called PC synch cable) was to blame. If flash fires correctly with the test button on the handle, then cleaning the cable contacts with contact cleaner spray seems to be the best first step.
Regards,
Gerard
Mar 07, 2008 | Cameras
Flash stopped workin as master in wireless mode?
Hi Joelgue,
Now, go to a real camera store and bring your equipments with you.
Say to them:
I have a Canon 580EX Flash and wanted to know if you have the Quantum Turbo Battery with the Adapter Cord for my 580EX?
Ask to see if you can test them out.
This adapter does not go into the 4AA battery hold but to the flip out cover, AC Adapter. You need to plug it into the flash.
Press "On" from the Q battery, then set flash to "Master" on camera and other EX to "Slave".
Turn all three on(1st flash, 2nd flash and camera.
Do not press shutter button but press the pre-flash(pre-auto lock/flash) on camera body. On the EOS-1Ds Mark III has "*".
Both flashes should come on.
Now, press the camera shutter using "ETTL Modes" and look at the image from the LCD screen...is exposure correct?
Address to this address from now, please: atdlee@netzero.com
PS: You did set both flashes into same channel and with no exposure adjustment, right?
May 25, 2007 | Canon SPEEDLITE 580EX TTL Flash
Powershot S1 Digital Camera: Flash won't fire
Make sure the camera is not in Document mode . Document takes a picture with added contrast so text stands out. Make sure the camera is not set to Infinity focus . When you select Infinity Focus, the camera automatically turns off the flash and auto focus so you get sharp, clear pictures. Make sure the camera is set to Fill, Auto, or Red Eye flash. See your camera manual for details about setting the flash.
Dec 31, 2005 | Canon PowerShot S1 IS Digital Camera
Newer features
4 Nickel Metal Hydride (Ni-MH) Batteries w/Charger included. • 8 MB SmartMedia Card included. On the web it says that Two 8MB SmartMedia Card included. • 6 Step Manual White Balance/ Color Temperature Control. • Burst Mode: up-to 5 images in 1/3 second intervals at any resolution. • External Flash Sync/PC flash connector. • 3 position quick focus settings: 1.3ft, 8 ft., and infinity. • Battery Saving Mode. • Rapid Fire Capabilities all resolution modes (even with the flash on). • 6 Mode pop-up flash system, including Auto, Red Eye Reduction, Fill in, Fill in with External Flash, External Flash and Flash Off.
Aug 31, 2005 | Olympus D-500L Digital Camera
HP Photosmart M22 Digital Camera Logo
47 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
