Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Replace lid switch - Whirlpool LTE6234D Top Load Stacked Washer/Dryer
  • 68 Answers
Try this link it really should help!!!! have a GREAT DAY and don't forget to give me a ranking!! THANK YOU!!
http://fixitnow.com/wp/2007/05/16/getting-to-the-lid-switch-in-a-kenmore-top-loading-washer/
Posted on May 10, 2009
My washer stalls at the end of the wash cycle and I can hit the lid with my hand to restart it
Sounds like your lid safety switch is bad. Replace the switch. If this is a unit with a hidden lid switch, left rear, you may only need tighten your lid hinge screws.
Jan 01, 2015 | Kenmore Washing Machines
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
My Kenmore elite 100.24942301 Lid switch problem
You may can slightly bent the part the lid contacts so it will be depressed further thereby making the switch. If that doesn't work then you will need to replace the switch.
Washer lid switch replacement
there is a screw right on the edge of where the clothes go in the washer on the right side,remove the top cover ans unplug lid switch harness, remove lid switch and then replace lid switch and reverse the procedure
Oct 28, 2009 | Sport & Outdoor - Others
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
My wsher agitates but does not spin or rinse
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, this is commonly caused by a lid switch malfunctuion. I would recommend you check your lid switch first due to the frequency of use and the fact that it is the most common cause of these symptoms and least expensive to repair. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If parts are needed, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a kenmore 60 series that does not agitate or spin. I replaced the motor coupling, put everything back together, filled the washer and waited for it to agitate and spin, but nothing happened. What...
Check your lid switch. If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain, this is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If not activated by a lid strike, other models have the lid switch located under the washer casing next to one of the lid hinges. It is activated by a rod contacting an actuator. The mounting scews for this type are located under the operator console.
If you determine the switch to be defective, the following link explains how to access the washer interior and replace one:
If the switch requires replacement, a new one can be purchased on line at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of a replacement is $25 to $35.
NOTE: Pounding on the lid or storing heavy items on the lid can contribute to premature failure of the lid switch.
If you have questions, please let me know. I hope this helps you.
PS I'm trying to rule out the possibility of a bad timer. The lid switch is the most common fail item on this washer and can give symptoms of a serious problem. The timer is more expensive to replace, so its worth double checking the lid switch to be sure.
Aug 23, 2009 | Washing Machines
Kenmore 70 series
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working.
On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $25 and is fairly simple to replace if you follow the steps below:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
You can find a replacement at searspartsdirect.com. If you need further assistance, please post back and let me know.
May 10, 2008 | Washing Machines
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Question about whirlpool catalyst 27" washer
F3 means lid switch failure. Heres what the service manual for your washer says about the failure.
Flashes if the lid is NOT opened after the cycle was completed. The
electronic control board must detect that PAUSE/CANCEL was
pressed during a cycle or the lid was opened at least once at the end
of any cycle. This is continually tested to ensure proper lid switch
operation. If “F 3” is flashing, check continuity of the lid switch.
• With the lid closed, lid switch contacts should be closed.
• With the lid open, lid switch contacts should be open.
• If the lid switch has failed, replace it.
• If the lid switch is good, replace the electronic control board.
Apr 05, 2008 | Washing Machines
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
179 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
