I try to open photos on My Pictures but a message pops saying "file not supported" so it won't open. i have a Gateway laptop and use Windows if that helps.
You did not mention your picture file types. mostly default software in windows only supported opening jpeg formats. other file types like those captured by high end camera can be open with photoshop or similar software. to check this right click on the picture and on the popup option go to open with> your system might suggest application that can open your picture usually windows photo viewer or MS office picture manager
SOURCE: Installation Failed message trying to install Win XP SP3 on Gateway MX3225 laptop
What are you trying to install? It got cut off.
Swap file is set in different locations depending on your operating system, so please provide that as well.
However, the swap file is not related to installing an application or Windows.
Another thing to check, is to see how much RAM you have. Windows Vista says you can run it with 1Gig of RAM but it really needs 3Gig to work well. You'll also need to double check your CPU, CPU speed, hard drive space free.
Please let me know those things, then I'll be better able to assist you.
SOURCE: help and support not opening
This will be a virus or hard drive problem. Run you anti virus to see if it finds anything that may be eating up your system. If doesn't find anything, then try a system repair with your recovery or operating system disc, this will fix the missing or corrupt files. If you have any issues during or after the repair then you can assume that the hard drive is going out. More that likely a sector is going bad.
SOURCE: HP Pavilion dv6000 driver not reading Sony Memory Stick Pro Duo
hey i have the same problem with the hp pavillion 6000. It is one of the most unreliable computers in the world but i guess thats another discussion... I have a 2g memory card that will only be recognized if i restart the computer and put it in then... Once you eject it though it wont recognize it. HP needs to get their **** together and stop ripping people off.
SOURCE: Cannot open any word documents, pdfs, photos etc.
Hi angela_sing
You can open your word documents, but not the ones sent by others, and you say you could open them before.
Well, I think the person(s) who sent the word documents before have upgraded to Word 2007. An earlier version will have difficulty in reading newer versions, so requires conversion. First of all, please check with the people who send you the word documents before you reinstall the O/S
Regarding photos, normally you would click on them and they open. But if a photo does not open in this manner, try the following:
Rifht click on the name of the file - you get a popup menu - instead of clicking on OPEN, you click on the OPEN WITH, Now a list of programs will appear which may be able to open your photo. Try each one of them, am pretty sure you will be lucky.
The same method can be used for your Word file as well.
Wish you all luck.
If this solution help you, please give a rating.
luciana44
SOURCE: gateway laptop (windows vista) internet won't work
Within Internet Explorer, click FILE, and WORK ONLINE.
