Question about Proscan PS50700 50" Rear Projection Television
No power Set does not power up. No sound or picture. Not even power indicator light. Im thinking maybe power supply or transformer of some sort. Not really sure. Please help !!! Thanks !!!
  • 4 more comments
  • ss69 Oct 12, 2007
    Thanks Terryfic !!  The service number is PS50700YX3 and chassis number is PTK195F3L. Im a do-it-yourselfer and appreciate your help.
  • asok26 Aug 17, 2008
    Also, Sometime its starts but menu button is not working.
  • rins71mc Sep 16, 2008
    I have the same problem. Can you provide more details about this repair? Like where this part/s located, size and shape? Thanks
  • Anonymous Nov 09, 2008
    have no idea what to do tv at least 10 years if not more
    no power at all going to tv.
  • Anonymous Dec 17, 2008
    television doesnt do anything when power on both remote and set are pressed.
  • gaidos Jan 08, 2009
    Picture was out of focus when turned on this morning, when I went to menu to try to see if I could adjust it just turned off and won't come back on. Tried unplugging and replugging after an hour or so--still won't come on. Is it something I could fix myself? Don't want to pur too much into a ten year old set.
    Genius:
  • 1,694 Answers
Probable IHVT aka flyback xformer.Also,check Horiz output
transistor.Please provide service number (three characters longer
than model number) & chassis # then I can give you part numbers.T.
Posted on Oct 12, 2007
  • Vista Electronics Oct 12, 2007
    IHVT Part # == 239111
    Horiz output xistor # == 237470 ( replace only if shorted)
    Let me know how it goes--T.
Tv turns on but no picture or sound, power light blinking
How many blinks does the light do? Or is it constant?
Jun 16, 2007 | Toshiba 27DF46 27" TV
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Sound but no picture. I'm thinking I need a new picture tube but how much is it going to cost me?
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Jan 30, 2010 | RCA P52936 52" Rear Projection Television
No power Up , No Sound , No picture
Im sorry tom have to inform you that a red light blinking is an indication that the main power supply is good BUT the sweep supply has a problem .. Most likly the high voltage transformer as well as the horizontal transistor is bad. if you have no solid state repair experience, you will not be able to fix this set on your own as we techs do gfo to school to learn the circuits in these sets and there are safety issues you have to know and equipment you have to have. sorry my freind but you going to need to call or take the set top a trained tech to trouble shoot as you cannot look at the board and see a problem. you have to troubleshoot the board and test the circuitry.
Aug 30, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
TV takes forever to come on and then very dark
IM Afraid unit required to be serviced , problem at the inverter transformer or faulty capacitors at the POWER SUPPLY unit , hope this helps AJ
May 25, 2008 | Samsung SlimFit TX-S2783 TV
TV just turned off by itself and wont turn on....
LCD type TV's ought to be the most reliable type, but these Polaroids all have early failures of the power supply. Only way to fix it is to replace the whole electronic module. Call Polaroid cust. service and be persistant because they are used to abuse from angry customers. Well, it is possible to replace the elec. caps in the power supply and maybe the FETs, but us experts are kinda keeping those details for the paying customers.
Good Luck
Feb 22, 2008 | Polaroid FLM-3232 Television
Philips HDTV
usually the high pitch noiese like this indicate some kind of power supply problem. The power supplies inside are called "switching power supplies" and if they're overloaded will make the kind of sound you describe. It sounds like there's a serious problem within. Probably should have it serviced.
If you had an older set, I'd say the flyback transformer has malfunctioned, but I don't think they're in todays set.
Let me know what happens... please rate accordingly.
Dec 19, 2007 | Philips 60PW9363 60" Rear Projection...
Buzzing noise with no picture or sound.
The power supply is telling you that it has a short. I think you have a bad high voltage transformer in the horizontal deflection circuit. I've repaired several RCA's with this very same problem. The newer RCA's are vert prone to high voltage transformer failure ! Stargazer
Aug 20, 2007 | RCA F36649 36" TV
No Picture No Sound
I think you have a short somewhere inyour set most likely the horizontal output transistor which may have shorted by the high voltage transformer going bad. The faint ticking sound that you hear is the power supply trying to start but the shorted load won't let it. Stargazer
Apr 22, 2007 | Samsung TSL3099WHF 30" TV
Proscan PS50700 50" Rear Projection Television Logo
132 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
