Question about Acer AL1716B 17" LCD Monitor
Acer Al1716 I got this Monitor and it will not turn on.. it is just over a year and a half old.. No power or power lights.
  • 3 more comments
  • DANCON Nov 21, 2007
    I have the exact same problem as teddysmom. No power, nothing, completely dead. Unfortunately the only solution was to buy a Dell!
  • omega776 May 10, 2008
    Same problem here. Trying to fix it.
  • peterocket Jun 04, 2008
    Same here!
  • englishsette Aug 16, 2008
    Same problem here....No power LED and no power to monitor. I have swapped out with another monitor so cables are not a problem. Nor is the power source....
  • humanforklif Sep 13, 2008
    My Monitor did exactly the same.For a couple of months it would seem to restart itself,go blank then show the acer logo,then it would go back to working fine but ,all of a sudden, after I turned it off for the night,kaput,no power,no light at the power button nothing. New Monitor time I guess?Tried different cord different plug etc...
Need to replace the power inverter board..
Posted on Sep 20, 2008
SOURCE:
What is the screen resolution for acer al1716 monitor
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
May 16, 2010 | Acer AL1716 17" LCD Monitor
No power to acer al1716 the power light wont turn on at all no acer flashscreen
You have a common problem for monitors 2-3 years old. The internal power supply has died. If you can solder you should be able to do the repair yourself. Go to our web site at: www.ccl-la.com/badcaps.htm and look at the pictures. Open your monitor up and look for parts that look like the pictures on our site, replace any you see. The values to use are located on the sides of the bad caps. Be sure to use high temp (105c) replacements, not ones from Radio Shack, they will blow out in no time because of the high in the monitors. We carry them in stock or you can order them from several places on the internet. If you don't want to do the repair yourself we can do it for you. We charge $35 + return shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Sep 12, 2009 | Acer AL1716 F Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
No power after monitor is plugged and turned on
seen this problem many times, do as above stated. Return the moniter to where you bought it, if just purchased. Contact Acer if it is still under warranty.
Apr 13, 2009 | Acer AL1716 17" LCD Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
MONITOR ACER AL1716
1. Unplug the AC power cord to make sure the power is off.
turn the monitor upside down, you need 2 people for this.
2. Pull the 4 hooks on bottom side of the base and hold.
3. Separate the monitor and base.
Nov 05, 2008 | Acer AL1716 17" LCD Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Acer AL1716 Power problem?
i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
Jan 18, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1716B 17" LCD Monitor Logo
410 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
