Question about AEG S70168TK Refrigerator
FAULTY LIGHT WHEN I OPEN THE FRIDGE DOOR THE LIGHT GOES ON AND OFF AND THE CONTROL PANNEL LIGHTS FLICKER IT ALSO LEAKED WATER OUT OF THE OVERFLOW A COUPLE OF WEEKS AGO
  • squashedboy Jan 08, 2008
    I have the same problem - internal light flashing on and off regularly every 8 or 10 seconds. Flashes in time with the panel lights which also makes a clicking (relay?) noise. No other problems.
    Any suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
You may have a loose connection in your mains wire to the fridge. Check the wiring in the plug
Posted on Oct 12, 2007
SOURCE:
I taped magnets on my regrigerator according to the suggestion from Samsung. It worked for a couple of months but now it went haywire.
Please help me understand the connection between magnets and the like flickering? Does the light act the same way when you open the right door? have you played around with the switch?
Dec 08, 2014 | Samsung Refrigerators
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
GS6SHEXN500 fridge light and display on temp control flickers and sounds like relay making noise
The problem could be very well a relay that has the contacts pitted or weak causing the lighting in display and the interior lights to flicker. Here is a GS6SHEXNS00 Parts List and the relays I can see are in a covered control box near the compressor on page 17 and 18 on the parts list 2304056 Electronic Control I will be here if you should have any questions, Thanks Sea Breeze
Apr 01, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light inside the refrigerator flickers (or not) and the door makes a buzzing noise when opened. There appears to be a small light flickering inside the fridge behind the vegetable bend. The refrigerator...
Sounds like the electronic control in the rear compartment by compressor may be bad . There is a light in the crisper as well I believe and that one and the main light are controlled by the control in back.
Dec 03, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Water dripping to bottom of freezer goes out on floor when you open door
Possible that it is the water that is overflowing from the defrsot drain tank from the bottom of the fridge on the rear.
You must move the fridge forward to take a look and to confirm if this is also from the tubing leak or from the evaporatorr tray.
If there is water connection the check the line.
Sep 22, 2010 | Frigidaire FRS26R4A Side by Side...
Amama Fridge lighting problem
First tighten the bulbs securely. If not loose bulbs you have a loose wire connection.
Aug 14, 2009 | Refrigerators
Water dispenser keeps running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
AEG S70168TK Refrigerator Logo
116 people viewed this question
Top AEG Refrigerators Experts
Tony
Level 1 Expert
Robert Kulkofsky
Robert Kulkofsky
Chris Huff
Chris Huff
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
