Question about Canon Pixma iP4500 InkJet Printer
Canon 9500 ink tank reading
I have a canon 9500 printer ,when i click on print it says the following ink taks cannot be regognised or it says ink tank errors have occured?any ideas,the ink tanks are new!
  • charliewryde May 11, 2009
    thanks for your help ,i thought that might be the case .
  • 60 Answers
I have encountered the same problem, and after doing some research I found it to be a faulty chip in the ink cartridge (tank) itself. The problem disappeared when I bought a new one. The cartridge in Canon printers are equipped with a chip to ensure that you don't use counterfeit or unbranded ones. I might also be responsible for reporting levels to the driver, but I suspect that it first & foremost is a tool for them to make you stick to their brand. One can figure why...
Posted on May 10, 2009
HOW CAN I REMOVE THE PRINT HEAD ASSEMBLY ON A CANON MX340?
Follow the given steps:
1. Confirm that the printer is powered on.
2. Open the paper output tray and top cover.
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 12, 2012 | Canon PIXMA MP130 All-In-One InkJet...
Black ink not printing
Dear Friend, Check & confirm the following will help you...
  • Check ink tank situates Properly
  • OR Install recommended Ink tanks in Perfect Order
  • OR Remove Tape[Confirm there is no Orange tape across the top of ink tank]] From the Ink tank
  • OR Replace Ink tank
  • OR Perform Deep Print Head Cleaning
  • OR The Print Head may Need Replacing
>i860_install_inks_animation Click here
Above picture is the Correct View.... If this helped you,Do rate ME...Thanks For Contacting FixYa....
Apr 22, 2010 | Canon i860 InkJet Photo Printer
Colour don't match the screen light blue on the screen will be light pink when printed
If you have used non canon ink tanks that will be the problem.'
If you have used genuine canon ink then you may have placed the tanks in the wrong place.
Also try using genuine canon paper as that could also be the problem.
Apr 10, 2010 | Canon PIXMA Pro 9500 InkJet Photo Printer
Canon Pixma 9500 suddenly starts producing light prints
I'm not sure if this is possible with the 9500 (it won't be if the 9500 uses chipped cartridges)...
But have you installed the photo version of a Magenta or Cyan in the Non-phone cartridge... ie: PM instead of M, or PC instead of C.
It's a long shot as I don't know that particular models age, etc... but it's been done (by me included *blush*).
Feb 16, 2009 | Canon PIXMA Pro 9500 InkJet Photo Printer
Canon Pixma ip1600 ink absorber full.
Dear all,
You need to reset waste ink counter to fix this problem by using General Tools. Check my post in Canon Inkjet Printer Forum for details. I cannot insert image more than 150 kb here.
Regards,
Nov 20, 2008 | Canon PIXMA iP1600 Printer
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
Inaccurate error message
According to Canon's website:
Details Print Friendly Version Issue: ERROR LCD: More than one ink tank of the following color is installed U071
Solution: Replace defective ink tank (MP500 / MP800)
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.).
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Aug 14, 2007 | Canon Pixma MP500 All-In-One InkJet...
IP4200 duplicate ink tanks.
Hello there scubadave,
I've gotten in touch with Canon and have somethinga little different to try. At the very least the error should change.(Sorry, gallows humor). Please read this entire response before takingaction.
After the upcoming test procedure, I have included alink and procedure to contact Canon tech support. The assure me theywill replace any faulty tanks.
The purpose of this exercise iseither rule out ink tanks that are behaving or isolate the one(s)responsible for the dupliucate error. You should write down the results of thistest. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3.Confirm whether the printer recognizes the installed tank properly. Ifit does, it will indicate it does not detect the other ink tanks, asthey are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5.If the printer at any time indicates two of the same ink tanks areinstalled, the cause will be the last tank installed. For example, ifyou inserted an ink tank earlier, and you later inserted another inktank, and it said two of the same inks were installed, the cause of theissue is the last ink tank.
Click here for the Canon PIXMA iP4200 support page
Then click on e-mail support.
Fill out the form.
Under description, supply the following info:
Error- Duplicate Ink tank problem on my Canon PIXMA iP4200
<Describe how error occurs>
I have replaced the <color in> question> tank, reseated it, yet the error continues.
Youwill also need to list what inks are being used in the printer. Statethe type of ink that is being used and the order that the tanks areinstalled in the print head.
Provide the exact part number (such as BCI-6C, BCI3eBk, etc.) if possible.
The Canon support rep assured me they will be glad to replace the malfunctioning tank(s) for you at no cost. Please
respond with the test results, and specify the ink tank(s) that were not recognized correctly.
They responded quickly, professionally and apologetically. They want to help get this resolved for you.
I hope this helps end the frustration you must be feeling. If you need additional help or clarification, click the ASK button.
Remember: Good things happen to those who Rate.
Mike
Aug 06, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma iP4500 InkJet Printer Logo
122 people viewed this question
old marine
old marine
