Hi it sounds like a hardware malfucntion Try a hard reset. Just unplug the power cord for 30 minutes or more, then try again.
well most printers have a reset code or sequence but not yours, it looks like a malfunction and the only way to fix it is to replace the main control board which will be expensive and not worth it.
you can get one off ebay
Link: http://shop.ebay.com/items/__all-in-one printer_W0QQQ5ftrkparmsZ72Q253A1546Q257C66Q253A2Q257C65Q253A12Q257C39Q253A1QQ_dmptZCOMPQ5fPrintersQQ_trksidZp3286Q2ec0Q2em14QQ_sopZ1QQ_scZ1
have a look this is the cheepest if you need more websites just ask
...its ok
year im ok with that find one and i will check it out for you.
thanks
Dont buy used printers
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
I did the hard reset more then once last night.....no difference.
Anything else I can do.....at all?
Ok Muzzi, I was afraid that was what you were going to type. Dang IT.
Do you know where there are refurbished All in Ones ? Amazon or ???
Not working at the moment and cannot invest in another printer
Thank YOU anyway.
Ok, going into Amazon to window shop :-). Ebay is ok, but I've had some bad luck with one of the purchases. Thank YOU Muzzi......sounds like that cartoon character....just had to say it...sorry.
Kath
I'm whining here. I'm in Ketchikan, Alaska, and everything has to be sent priority mail, so I'm just going to have to wait. No Lotto here either....
We can keep commenting if you want, or you can ignore and move on......your call.
More gripes.....even if it's next to free, shipping would be about 50.00.... Ok venting done.
Kath
Any H.P......least expensive , even refurbished in Amazon or anywhere. I'm still looking too. Shipping will probably be more then the All In One.
Thank YOU Muzzi for the offer, I better just forget it till I get a paycheck or two under my belt.
You helped a lot......Have a good week ahead.
Kath
Yes Muzzi was very helpful and cordial. I didn't like the end solution, but that's my problem, not his; a new printer.
Thank YOU again Muzzi :-)
