Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Smeg dishwasher EN50242
By Mrs B on Oct 12, 2007
drainage blocked - have remove all the filters but still water not draining out.
Same Problem
Feb 01, 2009
-   We have the same problem. Did you manage to fix. Ours drains when the machine cools down. I am fed up of calling Smeg out to the same problem. This machine is a lemon.Only plus is pots are clean.-   jsears
May 18, 2008
-   I have a Smeg STX-45 dishwasher. After washing the utensils, machine is not able to drain the water. Can you please tell me what could be the problem. Is there any switch I need to press for the same or something else. I have used the machine for the first time. -   samnit24
Feb 26, 2008
-   won't drain-   Guest
Dec 30, 2007
-   bosch dishwasher fails to drain.how do itell if it's a pump problem or a drainage obstruction?-   regfitz
Best Solution
posted on May 18, 2008
Very Helpful)
samnit24
Rank: Apprentice
Rating: 100%, 2 votes
Was this helpful?
Yes
No
Solution #2
posted on Oct 15, 2007
Helpful)
barnsleymick
Rank: Guru
Rating: 86%, 378 votes
does the pump actually work electrically, test for open circuit
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
what brand dishwasher should i buy?
Answer
What new dishwasher do you recommend. I have a family of 7 and the dishwasher is constantly in use.
Answer
my Moffat portable dishwasher won't fill up all the way. At first I thought it was the water... (More)
Answer
door spring broken
Answer
the dishwasher heats up but no water enters anymore. what happened?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
