Question about Dryers
How do i get access to gas valve coils on maytag neptune series dryer
How do i get access to gas coils on maytag neptune dryer
  • 68 Answers
Here is a link of an exploded view of a dryer hopefully this can help you! have a good day! Ps don't forget to give me a rating if this was helpful!!! thank you
http://www.repairclinic.com/0100_17.asp
Posted on May 10, 2009
Why wont my Maytag Neptune gas dryer stay hot when I'm drying my cloths?
If you are sure that it is a gas powered dryer, the problem could be thermostat, flame sensor etc.
Oct 05, 2015 | Maytag Neptune MDG6700A Gas Dryer
Runs fine low heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 25, 2011 | Maytag Neptune MDG9700A Gas Dryer
I have a Maytag Neptune MDG5500AW that is not drying. It sometimes has heat but most of the time it does not. Can you help me diagnose the problem?
if it has heat the first 15 to 30 minutes and then no heat you have bad gas coils,they are located on the top of the gas valve,just remove the two phillips screws,remove the cover and change out the coils,
Aug 04, 2010 | Maytag Neptune MDG5500AW Gas Dryer
No heat
it could be the thermal fuse on the dryer vent housing open,the radiant sensor or high limit thermostat on the burner tube housing,the ignitor on the burner that glows to ignite the gas,or the boost and secondary gas valve coils on the gas valve that open the gas valve to supply gas to the burner,all items need to be accessed thru the removal of the front cover and checked with an ohmmeter for continuity or resistance
Jun 20, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer gas valve.
Position the unit so the two coils are closest to you and the single regulator valve is in the back, The longer valve goes on the left (single coil). The short valve goes on the right and works with the split coil.
Jun 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
May 04, 2010 | Maytag Neptune MCG8000AW Gas Dryer
I have a Maytag Neptune MGD9700A dryer. It is LP.
Most times that is a sign that the gas coils are weaking. I am having a little trouble with your model number so I' not sure what your part numbers will be. Get with me later if you should find the model numer to be different. On Maytag they are inside the door. I am not saying that you are wrong but that I could find only this series MGD9700SB0 One coil should be part number 694540 Coil, 60 Hz. (2 Terminal) (Main) and the other part number 694539 Coil, 60 Hz. (Split) (3 Terminal) (Pilot Position) You can find these valve in a larger photo discription on this page=> Seabreeze Appliance Parts just click on photo to enlarge.
This is the 694540 and you can find Here=> 694540
daaffda.jpg And here is the part 694539 Gas Valve
Click Here=> 694539
b7ef152.jpg If you have questions you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 20, 2010 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune mdg6400aww heats up for 1-2 mintutes then not heat
Make sure there are no major airflow obstructions. If not, replace the coil packs on the gas valve.
Aug 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG5500AWW Not Heating
The coils are the #1 failure in gas dryers, below is a description of how they work. This excerpt from; www.repairclinic.com.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Jul 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer MD-6 - Moisture Monitor not lighting
Remove the rear vent and run a load. If it dries correctly, repair the vent blockage.
If not, replace the gas valve coils.
May 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryers Logo
208 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
