Question about Acer Aspire One PC Notebook
My aspire one battery does not work
Got it in December and have only used it a few times, always with the adapter.  Tried the battery today: It says the battery is 100% charged (checked using the adapter) but when I press the start button nothing happens.  Dud battery??
  • 62 Answers
These are known for having bad batteries
Posted on May 10, 2009
Acer aspire one D255 will not charge
You don't have a real serious problem. Just use the Power Cord. Now if the Power Cord does not work, that's a real problem. If your power cord is good and you can use your laptop with it, then the problem is your battery is bad if it will not take a charge. It's time for you to buy a new battery.
Apr 09, 2012 | Acer Aspire One D255-2670
Nuvi 1390 will not power on.
Try pressing and HOLDING the power button for up to 15 seconds (or until it powers up - whichever happens first). This is a hard reset - and should get you going unless the battery is discharged.
Oddly, batteries can discharge when the GPS remains on the car charger. Disconnect it and connect to the your computer's USB port (or AC adapter if it came with one) over night. The computer must be ON - "sleeping" is ok too - just not "OFF". This will charge the internal battery.
If it will not accept a charge, you may need to replace the battery or return the GPS to Garmin for service.
Nov 19, 2011 | Garmin Nuvi 1390 Car GPS Receiver
The S107 helicopter charged up successfullyfirst time using an Apple USB mains adaptor. I then tried charging it up from a computer USB and it would only partially charge with the machine turned on and the...
Is helicopter off when charging? Will not charge when powered on.
Light on charger should go off when plugged into helicopter.
Also, are you running battery dead? This will destroy a Li/Po battery. Never fully drain battery. Run only until you cannot maintain altitude. Land and power off. Cool for 10 minutes. Charge. Cool for 10 minutes. Skipping either "cool-downs" will also destroy your battery, albeit slower than the full discharge which can sometimes kill a Li/Po battery in only 1 or 2 cycles especially when they are new. Have any friends with a cell phone or laptop (Li/Po batteries also) that they hate because "it's always dying" or "the battery only lasts like 4 hours" whether or not they know why, it is ALWAYS because they rarely charge them fully, especially for the first few charges which are crucial, and the often run the things dead until they won't even turn on.
Back on topic, I use and recommend the usb power adapter. When plugged in using the USB wall adapter, does the charging light still stay on? Certainly if "yes", and still likely if "no" sadly, this to me sounds like a fried battery, which, if it, as I suspect, was caused by frequent or early full discharges and/or hot charging/flying... then you're screwed. The batteries are cheap but quite tricky to replace. Need a steady hand and a needle tipped soldering iron and solder barely thicker than hair.
Hope I've helped,
PvT
Jan 04, 2011 | SYMA Toys industrial New Syma S107 Mini...
After booted up and just sitting there for a few
Get the battery checked. Its malfunctioning. you probably might need to buy a new one.
May 06, 2010 | Acer Aspire 6920 Notebook PC
System Date Problem in EEE PC 1005HA
As if you have tried changing the date & time in your control panel plus BIOS.There is nothing left to be done regarding changing date & time.
But If your CMOS battery in the motherboard fails,it will always goes back to it deafult date & time.Replace the battery and it will solve your problem.
I recommend to use Sony Lithium Battery
Dec 21, 2009 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My computer is not coming on..I left it
Yes..ACER laptops have serious power and sound issues in my experience. Does it work ok with adapter power?
I wouldn't waste time buying another battery pack unless you really need to be mobile....because ACER laptop batteries give less than 60 minutes on battery...
Bottomline: If being mobile is absolutely important buy a new battery pack...
Dec 18, 2009 | Acer Computers & Internet
Battery wont charge
Well the battery is dead. I don't understand your question. You have always been using it on AC adapter, but today you tried using it on battery and the battery was dead? Use the AC adapter and watch the battery and see if it charges. If not take the battery out and then put back in and make sure it is snug so the contacts are touching..if it still does not charge then you need to notify Acer, its under warranty and tell them the battery does not charge and you want a new one..if you have any questions let me know..
pls rate this with 4 diamonds then you can still ask any questions you like.
Mar 28, 2009 | Acer Aspire One Netbook 8.9" Notebook
Using battery charger with 3.42A vs 4.74A for lap top
YOu can always use higher amps when required but not lower than required. Voltage should stay the same as original charger - keep it in mind.
Mar 02, 2009 | Acer Aspire 5100-3357 Notebook
ASpire 5580 series, no power
Hi Dhadha,
Try this: - remove AC adapter plug - remove the battery - insert the battery again. - try power up the laptop.
I have same problem, but this trick always work, and I always do this every power up. :)
However, I am using a usb optical mouse for an indicator. When inserting the battery, I check the light on the mouse. If it is flashing the second I insert the battery, then the power up will be successful. IF it is not, then remove and insert the battery again.
Try it.
Regards,
Dapid Candra
Nov 17, 2008 | Acer Aspire 5580 Notebook
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
